It is currently Wed Oct 29, 2025 7:12 am
Post new topic  Reply to topic  [ 124 posts ]  Go to page Previous 15 6 7 8 9 Next
 Post subject: Re: 5 lug swap
PostPosted: Fri May 27, 2011 9:41 am
Fastest On The Site
I found them on Rockauto, but they were 78 bucks each...
~Jared, owner and operator of The Black Widow
10.24 @ 142.86, 1.58 60'
http://www.JayRacing.com
PostPosted: Sun May 29, 2011 10:15 pm
Fastest On The Site
PostPosted: Thu Jun 02, 2011 12:15 pm
Why did u post a pic of the fronts? Did you get your rear hubs re-drilled?
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Fri Jun 03, 2011 7:14 pm
Fastest On The Site
..........because that is the beginning point of this thread. 5 lug swap, front and rear. I have yet to get the rear hubs.... still looking.
PostPosted: Thu Jul 21, 2011 9:26 am
Fastest On The Site
So I finally got around to ordering the rear hubs! I was measuring them and just wanted a second opinion on them being the correct ones. See pic
PostPosted: Thu Jul 21, 2011 12:02 pm
Nope, those are clearly not 114.3mm. Obviously too big. Send them back. LOL They look good man.
PostPosted: Thu Jul 21, 2011 4:39 pm
Fastest On The Site
!!!!!!!!!!!!!!!!!!!! You scared me... I mated them to my dsm rotors so they should work!
PostPosted: Thu Jul 21, 2011 8:07 pm
Where did you get these? I know Rockauto had them on clearance for $50 each a while back. Either way, they are the right ones. Knock 3 of the studs out. screw the dsm rotor down with one lug nut and drill away.
PostPosted: Thu Jul 21, 2011 8:09 pm
Also just to be safe, you may want to try them on your car or at least measure the inside of the bearing. Just to make sure they aren't expo hubs.
PostPosted: Sat Jul 23, 2011 12:32 am
Fastest On The Site
OK will do.
I forgot to ask, where can I get some brake pads for the rear calipers?
PostPosted: Sat Jul 23, 2011 7:06 am
Pretty much anywhere, they are the same as 1g dsm rear pads.
PostPosted: Wed Jul 27, 2011 5:25 am
Wish I would have known some of this stuff before I did my swap. I'm actually running dsm knuckles and hubs on the front of the car right now. I am using the Yoshifab camber plates, which are pushed all the way in. I want to lower the car about another few inches so I think I will be able to push them back out when I get new suspension. As for the tie rods, all I did was flip them. The tie rods themselves look fine to me, no crazy angles at all and the car seems to have no bump steer.
PostPosted: Tue Sep 20, 2011 9:10 pm
Sorry I'm late...
http://www.youtube.com/watch?v=jUBIAIDu9-I
http://www.youtube.com/watch?v=OiCTYJiem0U
http://www.youtube.com/watch?v=m6mRJ9ZImcY
I wish I could offer more for the FWD rear 5-lug stuff, but I AWDed it so I'm no help. I found this thread thanks to a subscriber question. This should clear up the process on the fronts pretty well for any newcomers.
@aaronsbig16g There's some good info about ride height for the fronts in the last video. It includes all the parts and part numbers I used for the front end. The Megan Racing DSM springs were $129 new but I really didn't need the rear ones at all (if you go through my AWD rear swap videos, you'll see why).
Edit: I also credited 89MirageMan and ColtsFan in the info section because really they're the ones that did all the heavy work many years ago.
Jafro
95 GSX
91 Banana Yellow Colt
PostPosted: Wed Sep 21, 2011 11:44 am
Very nice work once again :wink: . This should clear up a lot for others out there wanting to do this swap.
PostPosted: Thu Sep 22, 2011 11:05 pm
Great video's! Very informative and entertaining.
And thanks for the tips! I think I'm running dsm shocks right now but this winter I'm going to upgrade to a koni/ground control combo, for sure going to try to get my hands on a set of mirage fronts.
