It is currently Wed Oct 29, 2025 6:32 pm
Post new topic  Reply to topic  [ 124 posts ]  Go to page Previous 14 5 6 7 8 9 Next
 Post subject: Re: 5 lug swap
PostPosted: Sun May 22, 2011 5:10 pm
These hubs came on all 92 sedans whether they had drums or discs. The 92's had a separate drum, 89-91 the drum and the hubs was all one piece.
PostPosted: Sun May 22, 2011 9:03 pm
Fastest On The Site
by one piece, do you mean the drum/hub assembly was one piece??
~Jared, owner and operator of The Black Widow
10.24 @ 142.86, 1.58 60'
http://www.JayRacing.com
PostPosted: Sun May 22, 2011 9:46 pm
Exactly, the wheel bearing/race was replacable.
PostPosted: Tue May 24, 2011 11:09 pm
Fastest On The Site
Here is the start I got today at work: ARP extended wheel studs are sweet;)
I compared the expo hub to the eclipse hub and they are the same size. I think you could also just drill out the front hub just like the rear. They are the EXACT same! I got the knuckles powdercoated gloss black tonight at my buddies place, I will post pics later tomorrow.
PostPosted: Wed May 25, 2011 12:43 pm
Fastest On The Site
went to the junkyard today and the first one had crushed the 92 by the time I got there. The second place had a 92 colt, I found out it isnt the same as the mirage in that year:(
PostPosted: Wed May 25, 2011 1:05 pm
Yeah its weird. I have even looked at a 92 summit sedan and it had the one piece rear hub/drum. Yet every 92 Mirage sedan that I have found had separate hubs on the rear.
PostPosted: Wed May 25, 2011 2:09 pm
Fastest On The Site
off a 93 mirage
Looks the exact same as the picture on rockautos site for one off a 92.... just sayin
PostPosted: Wed May 25, 2011 3:03 pm
Close but not close enough.
PostPosted: Wed May 25, 2011 7:42 pm
Fastest On The Site
why you gotta put the bus driver hat on?
PostPosted: Wed May 25, 2011 9:57 pm
Not even sure what that means but I'm trying to help you and save you some trouble. If you put a 5 lug dsm hub over the 4 x 100 hub you will see that there isn't enough material there to re-drill to 5 lug. The hub is physically too small to drill to 5 x 114.3.
PostPosted: Wed May 25, 2011 11:56 pm
Fastest On The Site
yeah, thats all I was sayin;)! You put the bus driver hat on and you took me to school man! LOL!!! :finga:
I appreciate the pics, I just saw it today and thought it looked really close, but you showed me I was WRONG! :partyman: :prayer:
PostPosted: Thu May 26, 2011 8:46 am
I wish those hubs were easier to fnd used. I went through all this stuff back in 07 when I was building my 4g sedan and wanted to go 5 lug. I'm not sayning there aren't other ways to do it but from my experience re-drilling the 92 sedan hubs is the easiest. If this is something you want to get done asap I would bite the bullet and buy new hubs. In my 4-5 years of hitting the junkyards I have seen (3) 92 mirage sedans.
PostPosted: Thu May 26, 2011 11:53 am
Fastest On The Site
yeah that would be easier! I would rather pay the 30 bucks for two at a junkyard. I've spent about 240 so far on this whole swap.... Dont want to spend more! Need more GO FAST parts :supz:
PostPosted: Thu May 26, 2011 1:38 pm
Trust me, I know exactly what you mean. Little projects like this nickel and dime you to death. Maybe someone will stumble upon a pair for you but you know how it is, parts never turn up cheap when you need them.
PostPosted: Fri May 27, 2011 8:55 am
For The Record,\
89mirageman knows his stuff, I have my set of 92 hubs waiting to be drilled, they are just low on my priority list.
You can buy the hubs from rock auto.
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
