It is currently Wed Oct 29, 2025 5:57 pm
Post new topic  Reply to topic  [ 124 posts ]  Go to page Previous 13 4 5 6 79 Next
 Post subject: Re: 5 lug swap
PostPosted: Sat May 07, 2011 11:36 pm
Fastest On The Site
Did you drive it after you did the swap? What about bump steer???
~Jared, owner and operator of The Black Widow
10.24 @ 142.86, 1.58 60'
http://www.JayRacing.com
PostPosted: Sun May 08, 2011 11:29 pm
I did drive it. No issues. But then again, my car was at stock ride height.
1985 Mitsubishi Cordia
Build in progress
PostPosted: Mon May 09, 2011 10:40 pm
Fastest On The Site
Mine is lowered ALL the way down. but with it being so low, I was thinking it might not hurt to have the tie rod on the top, then it might be close to stock steering... Maybe...?
I am gonna look after I get the car back together...
PostPosted: Tue May 17, 2011 10:42 am
Fastest On The Site
92-95 expo knuckles, 1g 5 lug dsm hubs, 93+awd dsm 276mm front rotors, twin piston calipers. This will barely clear a 15" wheel.
These will actually still use the same 1 piece sealed wheel bearing that your current GVR4 knuckles use, not sure why you call that a crappy design.
Does it matter what year for front bearings and awd or fwd? or any 1g? Front expo knuckle awd or fwd matter?
Rear rotors year matter? awd or fwd?
PostPosted: Tue May 17, 2011 10:55 am
90-94 dsm front wheel bearings are all the same, awd,fwd, turbo or na. Same as the 92-96 expo, colt vista and summit wagons. From what I found on CAPS the awd and fwd expo's all use the same front knuckles. You want rear rotors for any 90-94 dsm. Fwd and awd are identical.
PostPosted: Tue May 17, 2011 11:17 am
Fastest On The Site
Awesome thanks bro!
PostPosted: Wed May 18, 2011 1:34 pm
Fastest On The Site
So 92 mirage hubs only? what about 93, 94 etc...
PostPosted: Wed May 18, 2011 1:55 pm
I answered that back on page 3 when you asked last time. :lol: Are you even reading this stuff?
PostPosted: Wed May 18, 2011 2:45 pm
Fastest On The Site
NO......................... :partyman:
This thread got way to damn long for me to scroll back a couple pages... I thought you had, but I guess I am a ra-tard. :ANAL:
PostPosted: Wed May 18, 2011 2:46 pm
Fastest On The Site
is it only the rear hubs from a 92 mirage? or any 4th gen? And my caliper will fit in the rear?
92 only, 93-96 4g cars use 4 x 100 hubs so they will not work
And the front rotors are the same between the expo and dsm? I will just order new rotors front and rear.
They are identical in size but remember one is 4 lug and the other is 5. Buy rotors for a 1g dsm. Also if it were me I would go ahead and get the 93+ awd front rotors and toss the twin piston calipers on
and the front expo and dsm rotors and calipers are the same.... right?
Calipers are the same between the expo and the single piston 1g dsm's. Again the rotors are different
I was going to pull the entire axle, but when I brought it up to pay for it they wanted 100 bucks for it! Then the car would have dsm front and rear everything.
Well unless you find the 92 sedan hubs used they are going to cost you around $100 or more so the dsm axle may be the cheaper route if you can make it fit.
AH!!!!!!!!!!!!!!!!!!!!!!
PostPosted: Wed May 18, 2011 3:08 pm
Promise me this, when you get yours swapped you will do a full writeup. 8)
PostPosted: Wed May 18, 2011 3:41 pm
Fastest On The Site
sure thing man! Will be a short one with some pics;)!
PostPosted: Thu May 19, 2011 10:41 pm
Fastest On The Site
stupid faggot locally said he had 92 rear hubs. Come to see and find out they are 93.... MotherF!!!!!!!!!!
So if anyone can find me some rear hubs I will love you! lol
PostPosted: Sun May 22, 2011 9:29 am
$58 each brand new, not a bad deal.
http://cgi.ebay.com/ebaymotors/2-REAR-S ... ccessories
PostPosted: Sun May 22, 2011 12:36 pm
Fastest On The Site
I assumed they were supposed to be for drum brakes. I searched through the junkyards locally for them and no 92...
Now I have got everything for the swap except the rear hubs! I will take some time to clean the parts and apply some sweet paint my buddy has that is like powdercoating them!
