It is currently Tue Oct 21, 2025 7:39 pm
PostPosted: Sat May 14, 2011 1:04 pm
I have one 1g AWD and two 1g FWD Three Speed scattershields, all of them are new, never used or installed. $145 shipped plus paypal fees each. I will try to snap some pics of them later today.
PostPosted: Mon May 16, 2011 6:35 pm
Here are a few pics:
AWD:
FWDs:
PostPosted: Mon May 16, 2011 6:59 pm
I will take 1 fwd scattershield if we know that it will fit the km210 fitted in the c53a.
PostPosted: Mon May 16, 2011 7:14 pm
Tim, they are build for the 1g dsm, is the km132 any larger in size that a dsm trans? I would expect not, but I really don't know.
PostPosted: Mon May 16, 2011 7:18 pm
it should work. i believe only the internals of the trans are different. My f5m33 says Km-210 on the bottom of the case
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Mon May 16, 2011 8:17 pm
I was thinking they were physically the same on the outside of the case. There is your answer Tim :D
PostPosted: Mon May 16, 2011 8:52 pm
I guess they should be if the bell housing and starter/plate locations are the same, being bolted up to the same block dimensions of the 4g6X (non-wide block variety).
PostPosted: Tue May 17, 2011 5:42 am
I know for a fact that the km210 and f5m33 use the same starter plate. Being as I have a fed dsm starter and starter plate in my mirage with the km 210 trans
2000 Lexus sc300
2016 ram 1500
PostPosted: Tue May 17, 2011 6:03 am
If your using the colt shift linkage you have to cut out a hole in the scattersheild. The linkage needs a passage to go through. I had to do that to my scattersheild to make it work. Just make the measurements and have someone with a plasma cutter do it.
PostPosted: Tue May 17, 2011 9:05 pm
Ah, fair enough. Good to know for installation time.
PostPosted: Fri May 20, 2011 12:44 am
One fwd shield sold pending payment, only one fwd left guys!! The awd shield is still available as of right now too.
PostPosted: Sat May 21, 2011 2:11 am
One fwd sold, one fwd and awd left fellas.
PostPosted: Tue May 31, 2011 7:00 pm
Up, one awd and one fwd still available.
PostPosted: Tue Jun 21, 2011 2:11 am
bump
PostPosted: Thu Aug 25, 2011 6:32 am
One fwd left, make reasonable offer.
