It is currently Wed Oct 22, 2025 9:00 am
PostPosted: Fri Apr 29, 2011 10:48 am
Since I hybrid the 9b turbo to the 13g, I have parts for sale!
I have the factory compressor housing from an 88 Mirage w/ 4g32bT motor. It's in great shape and has the nipple for the actuator feed.
I have a non-leaking wastegate actuator. It's not perdy at all lol! It is dirty, slightly bent (Will still mount up) and the top is dented in a bit. However it still works and functions fine it would help for someone whom has a leaky one.
CRHA from a 13g, water/oil line capable, had no idea if the turbo worked beforehard. There was so much carbo build up on the turbine side that the turbo couldn't spin. When I took it apart I cleaned it and now it spins fine.
TD04 Shaft w/ turbine wheel, cleaned carbon off wheel fairly decent. Spun fine when cleaned.
4G37 intake manifold upper/lower w/o throtle body. I am switching to a Cyclone head and am using the matching manifold.
4G37 EGR Block off plate
Fuel Injectors! 210's, 230's, 196's and 186's(?)
White, Pink, Black, and Yellow top injectors
2.0 cam gears
I may have additional parts too just can't think of anymore. If your interested shoot me a PM and make an offer. I will negotiate with any serious offers and purchasers, I can accept pay pal.
I also wanted to thank the site staff for allowing me to help others with these needed items. Thank you for your time.
1994 Laser R/T 4G37 Turbo
1992 GTA Trans Am 5th Anniv.
1989 Silverado
1984 Maserati Biturbo 2.5TT
1980 Turbo Trans Am
1976 Trans Am 455
PostPosted: Sat Apr 30, 2011 9:48 pm
BANNED FOR FRAUD
Location location location
Jason Veraldi
Scammer
PostPosted: Mon May 02, 2011 10:49 am
My bad man, I forgot it wasn't on my info.
Albuquerque NM, can ship if needed any where in the US.
1989 Silverado
1980 Turbo Trans Am
1976 Trans Am 455
PostPosted: Fri May 13, 2011 4:19 pm
Good stuff here! No one needs these parts :( :( :(
1989 Silverado
1980 Turbo Trans Am
1976 Trans Am 455
PostPosted: Fri Feb 10, 2012 3:03 pm
I still have these and trying to keep them from getting damaged or hung from under one of my buddies rear bumpers! Please help me find them a great home, offers are accepted!
1989 Silverado
1980 Turbo Trans Am
1976 Trans Am 455
