It is currently Mon Oct 27, 2025 4:06 pm
 Post subject: NEED HELP: 4g63 swap
PostPosted: Sun Apr 24, 2011 8:43 am
I have a 92 dodge colt and i am looking to do the 4g63 swap. I was wondering if anyone had like a walkthrough or place that helps with the wiring and things that arent obvious during the swap. I would also like if someone could help with like a parts list i may need.
Thanks
 Post subject: Re: NEED HELP: 4g63 swap
PostPosted: Sun Apr 24, 2011 9:12 am
http://www.4g61t.org/forum/viewforum.php?f=6
hopefully this helps, also welcome to the forums! --put your location in your profile also.
PostPosted: Sun Apr 24, 2011 9:59 am
http://www.4g61t.org/forum/viewforum.php?f=23
PostPosted: Wed Apr 27, 2011 6:00 am
Thanks guys this is really helpful and I think will make the swap much easier
PostPosted: Wed Apr 27, 2011 6:53 am
I also make mounts and an adapter harness. Look for my sticky in the FS section.
PostPosted: Wed Apr 27, 2011 7:39 am
I'd the car auto or manual? If it's auto let me know and I'll walk you through swapping to a 5spd
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Wed Apr 27, 2011 6:13 pm
Its an auto and thanks that would be really helpful
PostPosted: Fri Apr 29, 2011 5:44 am
First thing is track down a CSM (colt,summit,mirage) shifter,shifter cables, and 5spd brake/pedal assembly. Then go to your parts store and buy a new clutch slave and master cylinder for an 89 colt gt. Finally get yourself a km-210 5spd transmission from a 89 colt gt or turbo mirage.
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri Apr 29, 2011 8:46 am
Won't a fwd dsm transmission work in the colt?
PostPosted: Fri Apr 29, 2011 9:36 am
It will but you will have to swap the shift levers and the cable bracket over. I did a write up on this a while back, its in the archives. Its the first post that ColtiXim linked you to above. :wink:
PostPosted: Fri Apr 29, 2011 11:09 am
What Driverside axle works with a fwd Dsm trans? The Dsm halfshaft setup didn't work for me
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri Apr 29, 2011 4:30 pm
If it was an intermediate shaft from a manual car it should have bolted right on. You have to space one of the bolts out or use a dsm ac bracket though.
PostPosted: Fri Apr 29, 2011 7:05 pm
Yea I hear people say that they bolt right up, then I hear people say they need to cut 3/16 of an inch off the splines. The shaft that was in the car was cut. Maybe it depends on year of trans and shaft?? I just ordered an n/a 4g61 long shaft. We'll see how that goes.
Sorry for the thread highjack. But technically its helpful information.
2000 Lexus sc300
2016 ram 1500
