It is currently Tue Oct 21, 2025 12:53 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page 1 2 3 Next
 Post subject: complete part out!!!
PostPosted: Sat Apr 23, 2011 3:08 pm
prescison 6262r (ball bearing) 82ar. about 1k miles - $1000
jmf equal length manifold/ 44mm flange (about 1k miles) - $700
tial 44mm wastegate (black) not sure what spring - $200
1g aem ems version 1/ with sensors - $800
jmf polished race intake manifold/ newer version - $350
throttlebodys. com upgraded 1g nt tb - $100
presicion 1600cc injectors - $300
1g built head/ crower 272's (not brian crowers), 3g revised lifters, ferrea
1mm over valves, crower springs & retainers, 3 angle valve job, port and p&p. everything was cleaned and replaced at machine shop about a year ago. have receipt for work done. - $1000
built 6bolt block/ ross 8.3.1, crower rods, balance shaft elimator kit, arp rod, main and headstuds, oil pump and gears and water pump from mitsu, gates racing timing belt and alternator belt, mitsu 4 layer mhg, all gaskets were replaced when block was built. acl rod and main bearings. have the reciept for all the work dne at the machine shop. was built at evolution racing engines in amityville by gino. about 2k miles on the head and block together. -$1400
aluminum civic radiator/ 14 an aluminum bungs welded on. upper and lower ss lines. comes with thermostat housing and waterpipe. 14' jegs aluminum blade fan. strongest 14' fan there is. 2900 cfm. $350
moroso catch can/ 8an sb lines $150
aeromotive fpr w/ gauge - $150
tial 50mm bov (black) - $200
28x12x4 xs fmic 3' cold side with vbands, 2.5' hot side silicone couplers and tbolts, tail flange. made to fit in a colt. $300
stock 90 oil cooler w/ an fittings on cooler and housing side with black heavy duty hosing. -$150
89' white turbo colt shell/ no ps, no heat, no wipers. full interior, driver side seat ripped. euro corners, 1g tranny axles, moroso battery terminals and kill switch, 15" rota slips, walbro 255, intrax springs, kyb gr2s, megan racing 3' downpipeto mandrelben catback with black vibrant super stealth muffler. optima battery located in truck. jvc cd player. rare window visors from europe. car is originally from riverdale cali, has absolutley no rust. front and back strut bars. suspension technique sway bars. poly uretahne inserts all around. - $1200
rr 6bolt aluminum awd flywheel (looks just like act, looks brand new) -$150
brand new jegs 10 gallon aluminum fuel cell -$225
1g awd subframe complete -$200
4bolt rear w axles- $250
1g driveshaft $100
1g awd tranny and 23 spline transfercase - $250
brand new custom made awd cross member for a 89 colt -$200
galant vr4 front and back spindles -$100
aem wideband- $150
maximum performance 40psi boost, voltage, oil pressure. $100
entire car with all the awd parts- $6000
 Post subject: Re: complete part out!!!
PostPosted: Sat Apr 23, 2011 3:52 pm
How much for the car with no awd parts, but still running and driving?
PostPosted: Sat Apr 23, 2011 4:01 pm
WHY?????!
PostPosted: Sat Apr 23, 2011 4:10 pm
NO !
Wake up...
PostPosted: Sat Apr 23, 2011 7:49 pm
I kind of want to throw that stuff in with the car. I really want 6k, I'm already taking a huge loss considering mileage on everything and the prices I paid for parts. I know I'm not going to get anything close to what I put in but I don't want to feel like I'm completely losing out. Someone will get a colt that was built right and is scary fast. I gave this car alot of tlc and would like it to go to a good home. It still runs and drives, just took it out to my g/f's house.
PostPosted: Sat Apr 23, 2011 8:11 pm
pics of the IC set up installed and not?
PostPosted: Sat Apr 23, 2011 8:15 pm
I'm pretty interested in the car as a whole, I'll go to the bank next week and see if it's possible for me to get a loan
PostPosted: Sat Apr 23, 2011 9:59 pm
:cry:
I do understand though, GL with the sale!
PostPosted: Sat Apr 23, 2011 10:53 pm
I'm kinda intrested in the 4 bolt rear if it's still available.
Will it direct swap in with a 1ga W5M33 running a 22 spline case? Or is it a different ratio?
PostPosted: Sat Apr 23, 2011 11:49 pm
its a direct swap, and yes I still have it. A couple people on tuners asked about it but there alot further away then you so let me know.
PostPosted: Sat Apr 23, 2011 11:52 pm
keep me updated becaue i have alot of people hitting me up for individual parts. im going to try and hold off as long as i can to not start parting it out.
PostPosted: Sat Apr 23, 2011 11:55 pm
http://www.4g61t.org/forum/viewtopic.php?f=57&t=32019
ill try to get pics of the hotside but to be honest im really busy with work so ill try my best.
PostPosted: Sun Apr 24, 2011 12:20 am
Thanks, but im looking for something with a short route set up. Good Luck with the sale
PostPosted: Sun Apr 24, 2011 7:47 am
Sick build, good luck with sale
PostPosted: Sun Apr 24, 2011 12:33 pm
Aren't you from Brooklyn? I was going to buy your 1g blue talon last year.
