It is currently Mon Nov 03, 2025 3:55 pm
 Post subject: ecmlink v3 no tps signal
PostPosted: Sat Apr 16, 2011 9:25 pm
anyone running ecmlink v3.took out my dsmap and installed my ecmlink,now no tps signal.nothing help
PostPosted: Sat Apr 16, 2011 10:02 pm
So you've logged said tps signal? If so it 100% has to be in the wiring somewhere. Check to see if you are even getting voltage out to it.
PostPosted: Sat Apr 16, 2011 10:51 pm
i have power to the tps.but nothing reading,no volts or signal,now with my dsmap everything worked fine,no engine light,i do have a 94 ecu in the mirage
PostPosted: Sat Apr 16, 2011 11:06 pm
I'd try this http://www.plymouthlaser.com/tps.htm obviously if you get a 0 reading from one of the terminals then TPS needs to be changed.
PostPosted: Sat Apr 16, 2011 11:11 pm
The TPS is a three wire circuit.
One of the outer wires is the ground
The middle wire is your signal wire to the ECU
and the other outer wire is 5 volts regulated from the ECU
Back probe the sensor, and check for 5V coming into the sensor.
Next back probe the signal wire and at idle(throttle body fully closed) should be approx. .63 volts
If that all checks out good Ohm out the ground and insure it is good.
It takes less than 5 minutes to do these tests and it will help to let you know the condition of the sensor. Your best option is to do a potentiometer sweep test with an oscilloscope but not many people just have a scope laying around ahaha. Hope this helps narrow down the problem
PostPosted: Mon Apr 18, 2011 10:05 am
Is it indeed a 3 wire TPS or a 4 wire?
PostPosted: Wed Apr 20, 2011 11:00 am
its a 3 wire.i know how a tps work.just thought it was something in the ecmlink.now put the moates back in.ecmlink will go up for sale
