You didn't pay as much for the van new? lol
I dont understand.
now the build is on hiatus for a little while as i order up some parts.
I decided to use 92 gears as i opened up one of my mystery trannies and it was pristine condition 92 awd box. These are supposedly the strongest gears, also compatible with evo 3 stuff. These also have the shittiest 3/4 shift fork so i have to order evo shift forks, other than that i could have the box back together.
What i did was use the vans bellhousing section and thats it. I installed the 3 lower bearing races from the 92 box to match the 92 stuff, used everything else from the 92 box. checked all the preloads and they are good.
I also need a clutch, i have a new stock clutch, but no sense putting that in it would never last long even with a 14b.
And might as well do the t belt and all seals etc etc. Im going to leave the balance shafts in cause i dont want to piss around with high oil pressure. I want good street manners too so balance shafts in and stock flywheel too.
Keeping the air conditioning p.s, etc remote start, all that.
New, the van was cheaper than it other Mitsu counterparts; ie the sports cars, so parts would generally get hacked on by the accountants and engineers till they are on the borderline of breakage at elevated power levels. hehe Less metal = less expensive.
