It is currently Thu Oct 30, 2025 11:43 am
PostPosted: Mon Apr 04, 2011 8:54 pm
I am swapping to twin piston diamante calipers and gvr4 rotors, and want to upgrade to braided stainless lines during the swap.
do i need these adapter lines from roadrace engineering? or will the regular 1g gst stuff work like the rest of the swaps? need to know soon so i can order parts asap
PostPosted: Mon Apr 04, 2011 9:29 pm
Depends on what you got the caliper from and if it has the screw in style lines or the banjo bolt style like the rears.
PostPosted: Mon Apr 04, 2011 9:56 pm
dammit, i dont remember, ill have to swing by the storage unit tomorrow to check em out.
PostPosted: Tue Apr 05, 2011 4:36 am
CSM Dik
For what it's worth I picked up these banjo adapters off the rear of an na laser at Pull A Part,saw them on a na Talon too. A 1g brake line will thread into the adapter. Calipers were off a Diamante with banjo bolt-style lines. I haven't used them yet but they appear as though they will work out fine.
Dale
PostPosted: Tue Apr 05, 2011 10:11 pm
good lookin out guys. i havent pulled too many brakes apart on alot of mitsus, other than csms and 1g dsms. the calipers i have are the inverted flare 1g style, so i just ordered brake lines for it.
fyi extreme psi has 1g lines for 115 plus shipping. sure beats the 190 for goodridge.
