It is currently Fri Oct 24, 2025 9:27 pm
PostPosted: Wed Mar 09, 2011 1:52 pm
can you use 2pot calipers in place of the 1g 1 pots, it was never mentioned in this guide:
http://www.4g61t.org/forum/viewtopic.ph ... 2&start=30
PostPosted: Wed Mar 09, 2011 3:37 pm
No, you need a much larger rotor to use the twin piston calipers.
PostPosted: Wed Mar 09, 2011 3:53 pm
Elantra rotors are like 258mm, Mirage/Colt Turbo are 266m, 1G Talon/Eclipse/Galant VR4 are 276mm IIRC.
Each rotor requires the caliper that is most specific to the original application, barring a few exceptions, but that is the general rule of thumb.
PostPosted: Thu Mar 10, 2011 2:02 am
but, you can use 1g 1 pots with elantra front rotors yes?
PostPosted: Thu Mar 10, 2011 9:29 am
Yes, thats what I used. The stock front calipers from a 94 fwd turbo laser.
PostPosted: Thu Mar 10, 2011 1:41 pm
ill just stick to the proven formula. luls, thanks guys.
PostPosted: Thu Mar 10, 2011 4:34 pm
CSM Dik
Or just do this http://www.4g61t.org/forum/viewtopic.php?f=22&t=33524 and switch to the dual piston set-up
Dale
PostPosted: Thu Mar 10, 2011 6:35 pm
already got my elantra rotors and im picking up a free set of dsm 1 pots on saturday:)
PostPosted: Thu Mar 10, 2011 7:25 pm
Another great option, same way just another view is shown in this thread; dual pot VR4 upgrade:
Suspension archives section
http://www.4g61t.org/forum/viewtopic.php?f=10&t=24309
PostPosted: Mon Mar 14, 2011 5:07 pm
Going this method with floating rotors and a spacer will also set your wheels out the same distance. So figure in a good 10-15mm wider on each side. Not a huge difference or a deal breaker, but keep this in mind.
PostPosted: Mon Mar 21, 2011 1:48 pm
was up at pull a part getting my calipers for the brake upgrade on the colt, next to the 1g i was stealing parts from there was this guy:
factory awd, no engine or trans but i saw no rust on it either, needs alot of this and that. thought id pass it along, something that hasnt been done in cleveland yet as far as i know.
i ended up getting the passenger side caliper/bracket from a 94 eclipse fwd/t but on the driver side we snapped both bolts and a 3/8's breaker bar! i took the caliper from it anyways, and then took the caliper bracket from the expo in the picture, side by side i can find only minimal differences and the rotors were the same diameter, does anyone know if they are truly interchangeable? visually id say yes, infact im 90% sure but it never hurts to ask.
