Sounds like you may be talking about the ISC. For the TPS I just probe the wires with my ohm meter, switch the car on and adjust it until its getting the correct voltage.
Ok. So i am a bit confused. The TPS should be set by voltage when the car is running or just with the ignition switch turned? Are you aware of a way to make sure the ISC is operating in sync with the ecu? A friend of mine is having problems with high idle(bout 3k) on startup after a fresh rebuild. It's definitely not cable related, and i just want to make sure everything with the throttle body is working correctly.
