It is currently Tue Oct 21, 2025 6:49 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 178 posts ]  Go to page Previous 18 9 10 11 12
PostPosted: Tue Jul 20, 2010 11:16 am
Looks good, I'm with Trev on this one though, I don't think you needed to move the bottom mounting point that much if you already modified the top, esp if your running the coilovers I see in the background.
PostPosted: Wed Jul 21, 2010 9:02 am
So these struts were also 8 inches shorter than stock?
Yeah I had the new Struts on the car and the wheels bottomed out in the wheel wells. This was what I had to do to make them work. I dont think both of these mods will be needed to be done by everyone maybe just one of them. But this is what I had to do. The new Struts were all the way extened also. This will give me the adjustment I need.
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Wed Jul 21, 2010 9:43 am
Holy bejesus batman! Where do the calipers go?
PostPosted: Thu Jul 22, 2010 7:12 am
Are you using that brake for speed control or dyno help? or both :lol: Ive heard about this in the rock crawling community, but never in racing.
That's just a random picture I googled; I thought it might help give inspiration. As for the applications, I've seen these used on drag cars. Mostly dragsters with huge slicks, or show cars like a tubbed out Wyllis coupe or something.
I personally would replace the trailing arms.
PostPosted: Sat Jul 24, 2010 6:40 am
I have mocked up the caliper and all I have to do is "notch" the new strut mount and it should work.
Adam
05'WRX
PostPosted: Sat Jul 24, 2010 11:06 am
That's good you're able to make it work still! Although you probably could have gotten away with some big front brakes, sense most of the braking comes from the front anyway.
PostPosted: Thu Sep 09, 2010 7:09 pm
So I've been lookiong at what I did and I think I'm going back to the way it was.
Adam
05'WRX
PostPosted: Sun Oct 24, 2010 10:36 am
Alright I picked up a new rear end for the car and putting the strut mounts back to original DSA specs.
Adam
05'WRX
PostPosted: Thu Nov 18, 2010 12:10 am
Here we go, new parts all around. Rotors and calipers are on. So are the rear axles.
Adam
05'WRX
PostPosted: Fri Jan 28, 2011 5:15 pm
Update : The driveshaft has been installed !!!
I had two days off work and decided the Summit was what I wanted to work on.
The install went good pictures to come.
Adam
05'WRX
PostPosted: Fri Jan 28, 2011 10:33 pm
:rock: Yay for motivation! 8)
PostPosted: Sun Jan 30, 2011 7:52 pm
Here are the rear mounts - they came out great- Nice and strong
Dive shaft needs to be shifted a little but I designed the mount so I could do that.
Adam
05'WRX
PostPosted: Fri Feb 18, 2011 11:57 pm
I have sold the car and will pas the legacy on to Warren. I'm closing this page this week and will let him start a new one. I will keep all the pictures and info up thos to help every one. It was a blast to work on and hope she will come alive soon.
