Update:
I have over 500 Miles after Balance shaft elimination.  All is good.  I was able to replace all seals and gaskets while I was in there, so Now all leaks are gone
  Now Im focusing on the body and getting it to look the way I want.  Im gonna try and Polish it up today.  Also,  Last week I got 29MPG.  I think it could have been better, but A few times I got into the pedal.
I re-Installed the original Radiator after having it cleaned out by a radiator shop.  The Civic Rad was not cooling well.  Plus I like to keep the engine bay looking factory
Another thing I did was Install some replacement front struts,  I went with Gabriels coz they were cheap.  I also cut one coil off the front springs.
Short term Plans:
(1.)  I have my Extra 14B stuff being ported right now, I will have  02 Housing Ported with External Dump, 2G exhaust Manni, 14b Hotside being ported to match the manifold.  I think it should be a good flowing 14B by then.  Then I may turn the boost up to 17Lbs.
(2.)  Find some 15" Wheels.
Long term plans:
(1.) Install MAFT so I can finally get this car tuned
(2.) Do a front brake upgrade. Im thinking of using a set of EXPO Knuckle/Hubs with VR4 dual pistons and Discs.
(3.) Fix the e-Brake cables!!!!!!!!!!!!!!!!!!!!!
