It is currently Mon Oct 20, 2025 3:45 pm
PostPosted: Mon Jan 17, 2011 2:17 pm
1989 mirage turbo hatch
It is an original 4g61t car
the build on here with pics and more info (if you are on the board)
http://mirageforums.net/viewtopic.php?f=14&t=40176
If not here is the pics on photobucket
http://s122.photobucket.com/albums/o280 ... %20mirage/
Mods
4g63 engine has 7k on it
.020 over 2g pistons on 1g rods, arp main studs,arp head studs,arp rod bolts,acl race bearings rods and mains, new oil pump with bse kit, new water pump, new timing set, 90 oil cooler set up.
Head
Decked, 5 angle valve job, evo 3 sodium filled valves, bc springs and retainers,evo 3 cams, mitsu mls head gasket, light port and polish job, stock intake manifold, 90 n/a throttle body, Taylor 10mm wires, jdm (Mitsubishi) valve cover
Turbo set up
Evo 3 mhi 16g, evo 3 turbo manifold,evo 3 o2 housing, 3in down pipe, 3in high flow cat,3in cat back with thermal muffler. Fmic with shorty piping , tial bov,gm 3in mas, gm maft translator. Oil catch can,evo 8 injectors, 190 wall pump
Brakes and suspension
95 mirage front knuckles with new wheel bearings,1g dsm 5lug hubs with new studs,rear 5 lug swap,new struts and shocks front and rear, new ball joints, new tie rod ends, 94 gsx 2 piston front brakes, slotted and drilled rotors front and back
Tranny
90 awd dsm tranny with welded center diff to make fwd, new front axels, act awd flywheel, act 2100 p.p with new oem disk, redline fluids, new master and slave cylinders
Inside
90 EPROM ecu socked with stock chip, auto meter - electric oil pressure, boost, volt gauges, Jensen flip out DVD 7in screen deck, kicker door and rear speakers, 95 mirage shifter box and shortened shifter, 95 mirage shifter cables, power windows out of a colt gt, new heater core, dsah is mint not cracked or faded at all.
Outside
All oem panels on the car. Chrome 90 mirage sedan grill, hella super tone horns, 1g dsm washer bottle set up
Wheels
3g eclipse 17in oem rims with summer tires
2g eclipse 16in oem rims with winter tires
As of right now the car is running n/a with the stock 90 header, reman 90 ecu, injen intake with stock mas. All the turbo parts will come with the car just have not put them on since it got cold out side and the engine was getting broken in.
There is no rust holes on it at all the car came from the south. The body is showing its age. The paint is faded and there is scratches and hail dents on it. The front seats are letting go at the seams and the drives has a hole in it.
Extras that will go with the car
Complete 2nd power window set up wiring,,regulators,switchs,locks and rods. Drivers and pass side windows,evo 3 m’s springs and evo 3 kyb adjustable front struts, 2 rear sub frames one dsm other galant to make a nice awd sub frame with. Center concel both pieces. Rear hatch plastic panels,antena, front axels that need new boots, 2nd hacth cover, there is other parts as well that will go with the car.
The car is in MN has a clean and clear title.
Willing to meet with in reason or ship it
4,000 with both sets of rims
Will take best offer also with the rims or with out
Will take trades and cash also (would just turn and sell your car)
Mark
You can text me at 7six3 3zerozero 74two9
95 evolution 3
98 awd spyder
01 mirage sedan
51 mercury m1 truck
89 mirage turbo hatch SOLD
95 mirage coupe 4g63t SOLD
93 mirage sedan 4g63t SOLD
Last edited by tkrperformance on Mon Jan 17, 2011 6:38 pm, edited 1 time in total.
PostPosted: Mon Jan 17, 2011 5:16 pm
CSM O.G.
that phone number looks a digit short
and pics always help the sale. I would like to see how the eclipse 17s look on the car
PostPosted: Mon Jan 17, 2011 6:40 pm
There is 2 links right at the top with a lot of pics.
One with just pics the 2nd with the build
95 evolution 3
98 awd spyder
01 mirage sedan
51 mercury m1 truck
PostPosted: Thu Feb 03, 2011 3:34 pm
will look at good offers or trades and cash. looking to move out 3 cars from my drive way
95 evolution 3
98 awd spyder
01 mirage sedan
51 mercury m1 truck
PostPosted: Sat Feb 05, 2011 2:14 pm
will take 3k with just the one set of summer rims and tires. Can meet up with in reason.
95 evolution 3
98 awd spyder
01 mirage sedan
51 mercury m1 truck
PostPosted: Wed Feb 16, 2011 11:29 pm
3k want it gone. a bone stock one local just sold for 3k it is more than a fair price for a built car
95 evolution 3
98 awd spyder
01 mirage sedan
51 mercury m1 truck
