It is currently Fri Oct 24, 2025 9:37 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Mon Dec 13, 2010 9:10 pm
chris pm'd me today and said that the trans mount will not require holes to be drilled. it will bolt up like stock
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Mon Dec 13, 2010 9:29 pm
I think when we suggested drilling the trans mount, we all assumed it was bolted up in the pictures.
Now that I think of it, I'm pretty sure I didn't have to drill mine untill I installed the larger AWD transmission. That, and I had to redesign it a little for the stepped bolt pattern on the AWD.
PostPosted: Mon Dec 13, 2010 9:42 pm
^Exactly, I already modded his tranny mount with the step and lowered the hole. The dsm engine mount on the front is the problem.
PostPosted: Mon Dec 13, 2010 9:45 pm
At this point chris thinks it is a combination of things. one being the 4g63 mount on the front of the motor, and the second being I have the rear mount bolt through the wrong hole. (the rear mount is redrilled and i have it through the factory hole)
So im going to fix these issues this weekend and see where it sits afterward.
2000 Lexus sc300
2016 ram 1500
PostPosted: Wed Dec 15, 2010 10:24 am
The rear mount should go through the factory hole? Shouldn't it? Why was it redrilled?
Definitely get a 1.5 front metal mount. DSM/CSM front mounts are very different in where they put the bolt.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Wed Dec 15, 2010 2:56 pm
I'm sure chris will chime in on why you have to redrill the mount in the rear.
2000 Lexus sc300
2016 ram 1500
PostPosted: Wed Dec 15, 2010 6:07 pm
I modified a 4G15 rear engine mount. They are stepped where the 4G61 mount is flat. I add a piece of metal so that it will have a flat base, by doing that it throws off the mounting hole (for the roll stop) so I just re-drill another one in the correct spot.
PostPosted: Thu Dec 16, 2010 12:32 pm
I C
I thought he had an elantra/4g61 rear mount.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Sat Dec 18, 2010 3:41 pm
Motors straight and bolted in nice and snug! :)
2000 Lexus sc300
2016 ram 1500
PostPosted: Sat Dec 18, 2010 4:24 pm
So I take it you received the mount today?
PostPosted: Sat Dec 18, 2010 5:26 pm
Yep got it today. As soon as I popped the 4g63 mount off the crossmember mount, the motor settled into its correct spot. After that everything bolted up as it should.
But now I have to take the intake manifold back off tomorrow because i snapped a brass nipple off. Other than that it should be coming together soon.
2000 Lexus sc300
2016 ram 1500
PostPosted: Sat Dec 18, 2010 10:19 pm
Good deal man. Great solution to a frustrating problem.
PostPosted: Fri Feb 11, 2011 4:59 pm
Run it. The CV's will take up any "slop" from the misalignment. Consider your hubs are much more out of whack during acceleration....
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
