It is currently Tue Oct 21, 2025 8:51 am
PostPosted: Wed Dec 08, 2010 1:09 pm
This is an awesome turbo. Unfortunately we were not able to spool this thing like we thought we were. Even taking it to 8750rpm did not yield any results. So the most this thing has seen is 14-15psi on a 2.0L motor. We bought it brand new. Not rebuilt. It has just a hair over 40 miles on it. It has been fed with a -4 feed line and a .065 restrictor the entire time. It is just as tight and free spinning as the day we installed it. We hate to give up, but we just are no comfortable with having to spin our engine to 10,000-11,000 rpm just to use this thing. And even then we are not sure it will still respond wihtout nitrous. Our loss is your gain, this thing is badass, but we just don't have the displacement. We tried, but just couldn't make it happen.
The compressor mesurements-
inducer-75mm
exducer-102mm
Turbine measurements-
inducer-96mm
exducer-88mm
The turbo compressor has a 5" inlet
It has a T6 1.32a/r turbine housing. It requires or uses a 5" exhaust and outlet. It is a v-band exhaust.
The compressor does have cast 3" elbow in it for the way we confgured it in out car. It can be removed easily though. It may be rough to try and salvage the compressor v-band. But it can be done and I will leave it up to thene owner to remove it so I don't damage it or do it in a way you don't like.
There are a few options with the turbo, we do have an open tang T4-T6 adapter. We also have the 5" exhaust and v-band clamp we can sell with it as well.
If there are any questions please give me a call. If you know anyone looking for a sizeable turbo, give me a call. It is a very affordable turbo that can flat throw down.
Steven Johnson
biglady112@yahoo.com
720-299-7057
Turbo-$500 sipped
T4-T6 adapter-$50 shipped
5" exhaust and v-band clamp-$75 shipped
http://smg.photobucket.com/albums/v739/ ... e%20stuff/
[IMG]http://img.photobucket.com/albums/v739/ ... 6017-6.jpg[/IMG
1985 Mitsubishi Cordia
Build in progress
PostPosted: Wed Dec 08, 2010 3:40 pm
Any 2jz owners on here
1989 Dodge Colt E [4g63T]
2005 Saab 92X awd-turbo :)
2003 WW EVO8 FlexFuel
PostPosted: Wed Dec 08, 2010 3:46 pm
Or anyone with a bigger motor
Build in progress
PostPosted: Thu Dec 09, 2010 5:49 pm
Anyone need an upgrade for their Mack truck?
LOL Big Im surprised you wasted you time/effort on this set up for so long!!
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Sat Dec 11, 2010 10:42 pm
Turbo sold tonight.
Build in progress
PostPosted: Sun Dec 12, 2010 12:01 am
Negative Nancy
What diesel rig is this going on now?
PostPosted: Sun Dec 12, 2010 12:09 am
It is going on a 426 inch camaro
Build in progress
PostPosted: Sun Dec 12, 2010 12:33 am
Negative Nancy
It should feed that small block pretty good. This is more my route. I like the imports, but this is my tree. Check out the large bish pressin on the firewall, that is I.
PostPosted: Sun Dec 12, 2010 5:56 pm
Now what lol? Are you going to run that spa turbo?
Nice S10 man..
PostPosted: Sun Dec 12, 2010 8:37 pm
That is not an s10.
The spa was underperfoming. And was sold to me and I then sold it.
Another borg warner of a T4 flavor. Picking it up monday.
Build in progress
PostPosted: Mon Dec 13, 2010 12:26 am
That is not an s10.
What is it a 1500?
PostPosted: Mon Dec 13, 2010 4:28 am
Nope, a 4000
Build in progress
PostPosted: Thu Dec 16, 2010 7:57 pm
Negative Nancy
That is not an s10.
What is it a 1500?
Its my 1976 Chevy C10 1/2 ton.
PostPosted: Thu Dec 16, 2010 8:14 pm
That is not an s10.
What is it a 1500?
Nice what are your plains for the engine N/A F/I?
PostPosted: Thu Dec 16, 2010 8:20 pm
Find another thread or take it to pms.
Build in progress
