It is currently Wed Oct 29, 2025 11:34 pm
 Post subject: difference between ecu's
PostPosted: Sat Dec 11, 2010 8:06 pm
i have a 93 elantra i found a couple eprom ecus from a 94 or 95 elantra with the 1.8 dohc. the ecu plugs are diiferent. the plug is big meduim small and mines is the same as a dsm. ill post pics later
sorry looking at the wrong ecu
its big small meduim
PostPosted: Sat Dec 11, 2010 9:52 pm
the 94-95 ecu
my ecu
PostPosted: Sun Dec 12, 2010 9:54 pm
94.5 the Elantra changed over in electronic design among a few other things IIRC, that was the turning point for that model away from the 1G swap.
That being said, I wonder if that meant those motors changed to MAP like the 93 Colt/Summit/Mirage or what, but if your plugs don't work, then it's not going to happen without pin swapping assuming the ECU's are controlling exactly the same equipment.
Oh, this is what I had pulled from a 93 Elantra back at our first site meet in Brantford, Ontario:
PostPosted: Mon Dec 13, 2010 4:21 am
i was going to make a patch harness to make everything work
