Yeah I think it's drivetrain related. The closest thing to the passenger side window which is driveline related would be the transfer case I guess (don't forget i'm RHD), the noise isn't as loud with the passenger window up and driver window down.
I'd check the fluid in the tranny and tcase -- from the drain plugs.  See what you find in there.
I'll give this a look. The gearbox oil is about a year old, and transfer case oil is about 2 years old. I've only done 4000km in the last 2 years because the car has been off the road a few times, but i'm wanting to try a different oil in the gearbox to see if I can get it to shift better anyway. Might do it this week and see how it goes.
Throw out bearing?
I've always thought when a throw out bearing goes bad, the noise it makes goes away when you push the clutch pedal in? With my problem it doesn't seem to matter whether the clutch is engaged or not. The clutch is about 2 years/4000km old.
Check out the carrier bearings for the driveshaft. I recently had to replace both them on my Galant because they were almost 100% torn through. They were so sloppy from being so torn the driveshaft had lots of room to wiggle and vibrate. It definitely made the noise a lot worse on deceleration.
Yup I know this noise. Used to make the whole car vibrate, definitely different to what i've got now though. I replaced the driveshaft carrier bearings about 3 years ago, they're still fine.
