It is currently Tue Oct 28, 2025 3:42 pm
 Post subject: ID this compressor wheel
PostPosted: Mon Nov 29, 2010 10:06 pm
The inducer measures 50mm, the exducer measures 68mm. The calculated trim is 54. It came out of a MHI 16g turbo with a machined compressor housing that was onced owned by Rob (89d15 yada yada yada). The measurements don't fit a 20g wheel and the fins don't look the same. Anyone know if it is a 17c wheel?
PostPosted: Mon Nov 29, 2010 11:42 pm
I believe it is a TD05H-18G 18G 50.5/inducer 68.0/exducer 55 trim
lots and lots of info here...http://www.evocoupe.net/forum/viewtopic.php?f=2&p=38780 :)
PostPosted: Tue Nov 30, 2010 12:00 am
may not be an 18g wheel. g wheels are superback and have dual fins (high and low) not all the same height.
might be out of a volvo tdo4hml 18t.
PostPosted: Tue Nov 30, 2010 12:38 am
Wow underpsi that page is awesome. Saved the link for future use.
The inducer is definitely 50mm as I measure it but the fins could have been damaged thus decreasing the diameter. On Forced Performance's page they sell Typhoon/Syclone 17c turbos and visually the wheels look similar(12 blades of the same size rather than high/low blades). But it does not match the specifications on that turbo. I did shoot them an email. Thanks for the help guys!
