It is currently Fri Oct 24, 2025 10:12 pm
Post new topic  Reply to topic  [ 44 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: My '89 d50 build
PostPosted: Wed Jul 28, 2010 5:06 pm
I haven't updated the thread in a while, here are some pics of what has been done lately:
Built a new water pipe out of 304ss, it hugs the head pretty tight so I have ample clearance for the ext wg plumbing:
I also built a 4" intake pipe for the holset as well as a bracket setup to mount the trans cooler under the bed of the truck:
Built a completely new trans crossmember for the th350:
PostPosted: Wed Jul 28, 2010 7:08 pm
Very nice work John! Can't wait to see more progress.
PostPosted: Thu Jul 29, 2010 12:39 am
What exactly are you planning to haul with your truck, John? ;)
PostPosted: Thu Jul 29, 2010 4:42 am
Thanks Chris, Rollie-I am planning to drive and enjoy it! I am not sure where this build will end up, I have the other truck chassis that will be much more serious, I just want to get this one running and on the road for now. The leaf spring suspension may limit me on power :twisted:
I don't plan to haul much in the truck other than haulin ass :wink:
PostPosted: Fri Jul 30, 2010 2:11 pm
I think this is the last pricey peice of the puzzle, fits like a glove!
Moser billet slip yoke, solid forged 1350 u-joints.
PostPosted: Mon Aug 09, 2010 6:31 pm
looking good man cant wait to see it finished.
1989 mirage gt (drag car in progress)
PostPosted: Mon Aug 09, 2010 7:19 pm
I forgot to update this, I built the hotpipe saturday, it is a very tight fit for the GM maf, but it clears everything. The upper straight tube that goes to the throttle body is a piece of aluminized for now, I need to buy some more ss straight. I may also weld on some beads on the ends later. Once I go speed density, it will be much less bulky :)
PostPosted: Mon Aug 09, 2010 8:15 pm
Are those your welds John? Mig or Tig? Looks like you're moving right along.
PostPosted: Mon Aug 09, 2010 10:45 pm
Chris, those are my welds, they were done with a tig.
PostPosted: Mon Aug 09, 2010 11:50 pm
I figured they were but I wasn't positive. What setup are you using? I really need to pick up a nice tig machine and a plasma cutter too once I have the funds. For now they are just part of my wish list though.
PostPosted: Tue Aug 10, 2010 2:35 am
The welder I used for those welds is my little HTP Invertig 160. It only does dc, so you can only weld up mild and stainless steel, and it runs on 120v or 240v. Miller has some smaller machines as well, if you want something a little larger that does ac/dc, they typically run around $1500-2k new(last I checked). I also have a Harris dual flow meter regulator so I can back purge ss tubing.
PostPosted: Fri Aug 20, 2010 8:34 pm
Pulled the engine/trans back out to do some work, got the wg plumbing all tacked together the other day, then I snapped some pics of all of the intake/hotpipe/exhaust bolted up. Here are some pics:
PostPosted: Sat Aug 21, 2010 6:54 am
thats some really nice work youve done so far. looks real good man!!! :D
PostPosted: Sat Aug 21, 2010 5:57 pm
What is the point for the flex pipe on the wastegate line?
4g61t.com
PostPosted: Sat Aug 21, 2010 6:36 pm
To allow some movement for thermal expansion.
