Dash, engine(to rebuild for fun and have a spare), ecu, seats(if they are better), mpi relay, carpet, guage cluster, cluster surround, clock, sunvisor clips, vents, (check for power anything), replace any sun damage plastics. Check to see if the radiator is newer than yours, battery is still charged.
For recycling purposes this stuff is worth money to recyclers separately:
The battery. some states recycle cats, and pay astronomical amounts if they are OEM. Grab anything that's aluminum or copper (ie:radiator, a/c parts, water lines, brake lines, fuel lines, basically anything white metallic that hasn't rusted yet). You'll end up getting more back if you separate this stuff ahead of time and don't turn it in to the same recyclers.
_________________ 4g61t.org
4g61t.com
