I have a factory KM210 in which I had previously installed a lightened factory 215mm flywheel, and CFDF clutch (was slipping due to PO abuse or my new found power/torque in combination).
I bought this DSM 225MM ACT 2100 clutch and pressure plate combination.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
ACT 2100 HD CLUTCH KIT TALON ECLIPSE DSM MB1-HDSS
Lightweight flywheel that I mated it to.
http://www.extremepsi.com/store/custome ... 646&page=1
Fidanza Lightweight Aluminum Flywheel : Mitsubishi Eclipse 90-99 Turbo #16363
THIS PART # FDZ-161651
Flywheel bolts for which you need to purchase a 12 point socket to install.
ARP Pro-Series Flywheel Bolt Kit (8-pieces): Mitsubishi Eclipse 90-99 #21611
ARP-203-2801
The flywheel bolts are actually 7gte bolts as labelled on the package but they are the correct depth for the thicker flywheel material.
Of course you can always use a stock clutch and flywheel combination, 225mm FWD 6 bolt and it will fit the starter and crank with no modifications.
