It is currently Sun Nov 02, 2025 9:52 pm
PostPosted: Fri May 14, 2010 4:59 am
CSM Dik
How do I take off the horn pad on my '89 Colt GT?? the wheels off-center by a considerable amount,and I can't find any screws on the backside like on my DSM.
Dale
PostPosted: Fri May 14, 2010 7:43 am
Are you sure the whole column isn't off center? If you just turn the wheel, your turn signals will always be un-latching at the wrong times. You might just need to adjust your tie rods.
PostPosted: Fri May 14, 2010 9:23 am
CSM Dik
I never thought about that,there was new tie rods put on before I got the car.
Dale
PostPosted: Fri May 14, 2010 9:55 am
If the car drives nice and straight and doesn't pull to one side you can also just uncouple the column from the steering rack and recoulpe them a few teeth off.
- Works in da bush
PostPosted: Fri May 14, 2010 10:40 am
They probably never aligned it. Your toe could be way off without making it pull. Just get it aligned.
PostPosted: Fri May 14, 2010 3:33 pm
CSM Dik
Thanks for the replies fellas! I thought it was just as easy to pull the pad off like my DSM,and align the wheel that way.
Dale
