It is currently Mon Nov 03, 2025 12:01 pm
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3
PostPosted: Wed May 12, 2010 8:12 pm
Here is my 2 cents on everything....Back in the day i did something like 302 hp on my 1.6l and 16g set-up...
Stock 4g61t with a exhaust cam from a 1g retarded 1 tooth...
3inch exhaust
hallmon boost controller
ebay evo 3 16g
evo8 fmic
560 evo injectors
2gmaf
afc-2
junk intercooler piping 2.5"
I know your thinking doesn't sound like much but it worked and worked well i dynoed at 22-24psi and was on pump 91 oct....
IMO..You should be a ok and you have picked a great set-up to get 300 + HP ON 91 OCT...
V3 is the shit one of the best programs out there you will idle just fine and get decent gas milage just have to tune it..The 2g maf will be fine unless you got the gm maf....Also if it was me find a non turbo throttle body and bore the intake throttle body flange to match...
One thing i didn't see is a wideband do you have one and if not get aem wideband easy install there cheap and work great also the sensor can be found for cheap with a little digging around..
Str8fuct......
PostPosted: Wed May 12, 2010 8:16 pm
Btw: Were are the pics? It's must in the builds section... :finga: :lol: :lol:
Str8fuct......
PostPosted: Fri May 14, 2010 12:31 am
I have 2 days to get it running :o , after I do I'll take some snapshots and make a summary. :finga:
4g61t.com
PostPosted: Sun Jul 11, 2010 10:11 pm
what ever happened still building this?
PostPosted: Tue Jul 13, 2010 6:01 am
Sorry for the delay for pics and of my project....
http://www.4g61t.org/forum/viewtopic.php?f=42&t=33015
4g61t.com
