This is red sleepers old car and csmshaun owned it also....I daily drive it right now it runs great..I don't need to sell it just putting it out there....
Mods.
Original '89 Plymouth Colt GT (turbo)
Stock NA 4g63 bottom end
-balance shaft delete
-GReddy timing belt
4g63 turbo head and cams
-dsm link v3 lite
1g exhaust mani
GReddy 18g mated to 1g O2 housing
Hall-effect black top CAS
full 3" exhaust w/ 36" glass pack muffler
-side exit in front drivers rear tire
manual boost controller mounted on firewall
aem wideband
Fidanza 8lb alum flywheel
ACT 2900 unsprung 6 puck clutch
OE alum 1g radiator with 12" push-type fan
GReddy FMIC core with custom back-door end tanks
-plumbed with 3" aluminum pipe cold side
-steel hotside that steps up to 3" off the turbo
Custom wiring harness with small tuck performed and fuse box moved next to alternator
Hallman pro boost controller
3" GM maf in blow-through configuration
8 gal fuel cell in hatch
-6AN braided line to and from OE fuel rail that has been modified to accept -8AN to -6AN converters
Aeromotive A1000 fuel pressure regulator
Dual in-line walbro 255lph fuel pumps running off of proper rewire
750cc PTE Rochester injectors
Optima battery behind passenger seat
6 point cage welded to NHRA specs
Grant steering wheel (I'll give yah the stock one)
Autometer water temp, oil pressure, boost and fuel level
Rest of interior is there and clean, speakers are intact but the head unit in the car is junk...
GVR4 brakes with Hawk street pads in front
High temp Valvoline fluid flushed through
Stainless brake lines all around
KYB GR2 struts up front KYB AGX out back
Ground Control springs and coil perches
eBay brand strut bars (only kind available lol)
Adjustable camber in rear via Ingalls upper control arms ($$$$ lol)
AWD swapped with 4 bolt LSD rear
Trans shifts good and the trans, rear diff and t-case have Lucas oils in them. Trans has a welded center diff.Makes noise but shifts good..
Custom 2 section driveshaft
The car has an oil leak like every other mitsu...
Very old pic has 2g wheels on it now but looks very simular...
