It is currently Thu May 23, 2024 8:10 am
 Post subject: awd swap problems
PostPosted: Sun Mar 14, 2010 5:41 pm
Im currently starting a awd swap with the evo engine that i have
the parts im usig are from a 6g galant "i think thats the model its kown as"
well last night we trial fitted the awd gearbox with the spare gti galant 4g63 non turbo that is from the galant we are using
after fitting the engine and gearbox we noticed that the engine and gearbox is sitting wrong and sits at an angle
i havnt got pics at the moment but i can take pics to show the angle it sits at, but also only the gearbox mount will bolt up but the mount on the cylinder head will not line up.
the car its going into is a glx uk model and not the gti, as far as i can see both models are exactly the same under the bonnet and chassis legs etc
all i can thik of is the awd models front chassis legs are modified at the factory to accept the bigger galant gearbox but i cant find any pics of non awd and awd models front chassis legs
can anyone shed any light on what is the problem and possibly provide any pics of the front awd chassis legs to see the diff between them and the glx uk model
mike
MPH now have our own forum for new and existing customers to view all our development parts and our R&D service
http://mphperformanceforum.co.cc/
 Post subject: Re: awd swap problems
PostPosted: Sun Mar 14, 2010 6:21 pm
I doubt anyone here will be able to help you out as we didn't get any of those models here in the states. But hopefully someone will be able to point you in the right direction.
PostPosted: Sun Mar 14, 2010 6:24 pm
all i need really is pics from your models so i can compare with mine and see if i need to cut and modify the front chassis legs
iv got a feeling that the awd chassis is diff in some way to my model
PostPosted: Mon Mar 15, 2010 10:29 am
can anyone shed any light on the problem i have
i will take pics later to show what i mean about the engine sitting wrong also
PostPosted: Mon Mar 15, 2010 4:04 pm
No difference on GLX and GTI chassis in EU.
I think you use a bad gearbox mount or crossmember ...
Pics please.
PostPosted: Thu Mar 18, 2010 11:28 am
Which drivers side mount are you using?
PostPosted: Sun Mar 21, 2010 11:16 pm
The only way we could help you is with pics, it's hard to describe what your talking about with out seeing it.
