It is currently Thu Oct 23, 2025 2:11 am
Post new topic  Reply to topic  [ 345 posts ]  Go to page Previous 1 2 3 4 5 623 Next
PostPosted: Tue Feb 23, 2010 8:10 am
I know I sold another elantra pedal on here back when I parted out my 94 elantra. Was that it? Couldn't have been a 4g setup because they are way different and look like a dsm pedal. Clutch/brake pedal are all one unit.
By using both the brake and clutch pedal assemblies from the same car I should be good but we'll see. I have noticed that the little tabs that make contact with the switches are in different places on the elantra pedals vs the csm ones.
PostPosted: Tue Feb 23, 2010 9:17 am
You sold me one when I first did the swap to my old red colt.
PostPosted: Tue Feb 23, 2010 9:54 am
Did you ever install it? What brake pedal did you use if so?
PostPosted: Tue Feb 23, 2010 6:01 pm
Ya, it worked great. I just cut the tab off the stock brake pedal and moved the brake light switch.
PostPosted: Tue Feb 23, 2010 7:56 pm
Cool deal but didn't the pedals end up being really close together? I guess it doesn't matter but I decided to just mod the elantra brake pedal since I went through the trouble of pulling it.
PostPosted: Wed Feb 24, 2010 5:41 am
They were pretty close, yes, but not close enough to cause any problems shifting or braking or anything like that.
PostPosted: Wed Feb 24, 2010 11:56 am
^^^^Like what he said, a similar operation on mine. Here's a couple pics.
Chris, I must be clouded, cause I remember only swapping out the clutch pedal....were they all a one unit clutch/brake?
I can't remember which car you got it from, but you sent me the pedal, clutch master, hydraulic lines, and slave cylinder.
Had to sawzall the tab off my factory brake pedal because of interference. I said "rigged" up the brake switch to work with the new pedal...this is what I mean. It's not going anywhere. I guess some people take their dash out to do the swap. I just hung upside down for a couple hours and got it done.
A different angle, you can see a bolt hole for the frame...the one spot the clutch pedal was not lined up on. No worries.
Good stuff - trucks bring it!
PostPosted: Wed Feb 24, 2010 1:37 pm
That actually looks like a csm pedal from what I can tell. The elantra one has 4 studs that go through the firewall but the csm one has 3 studs and one bolt. Also the elantra one has a coil spring that returns the pedal and the csm one has a long skinny spring that hooks under the dash. I guess its also possible that Hyundai updated their stuff too, I know mine was from a 94 or 95. I've sold so much shit on here I can't remember who got what. :lol:
PostPosted: Sun Feb 28, 2010 12:15 am
I dropped the front control arms today so that I could compare them to the Elantra arms. I just wanted to make sure they would fit and see what bushings I needed to order. The plan is to extend them a little so that I can use longer (and easier to find) dsm axles, I will also be using 4g 4x100 knuckles and hubs to get rid of the captive rotor setup. Since the Elantra's use a bolt on style ball joint it will be much easier to modify them for the longer axles.
stock 1.5 csm control arm
Elantra control arm with bolt on ball joints
PostPosted: Sun Feb 28, 2010 1:05 am
So is there a dimensional difference?
PostPosted: Sun Feb 28, 2010 6:00 am
I planned on filling in the holes and redrilling new ones for the ball joint to use the dsm axle.. (along with camber plates for the top) when u find out the exact amount the holes need to be moved can u post it..(or pm me)? thanks much. :partyman:
PostPosted: Sun Feb 28, 2010 10:38 am
They seem to be identical.
slowdsm- I will be sure to post what I find out.
PostPosted: Mon Mar 01, 2010 6:14 am
Isn't the width of a colt the same as a dsm? I am very curious what you figure out Chris seeing how I have a tote full of extra dsm axles. Do you know what the axle lengths for both a csm and dsm are?
PostPosted: Mon Mar 01, 2010 8:17 am
I remember another member on here posting that he extended each front control arm 3/4" and the dsm axles went right in. He used regular csm control arms but I'm thinking it should be much easier with the elantra arms. Once I get them cleaned up and modded I will post whatever I come up with.
PostPosted: Mon Mar 01, 2010 9:09 pm
Chris, keep in mind that my mirage is lowered quite a bit, and that after swapping in the elantra control arms my driver's side cv axle was maxed out. My situation was very unique it appeared to us all. I broke one axle, replaced it and broke another, and then the next one I replaced kept pulling out of the intermediate axle. I studied for a dsm axle that was close to 1 inch longer than the mirage turbo axle...I recall it to be just less than an inch longer, and it solved that problem in a snap!
And you know that I ride with natural negative camber....but I was thinking how much more you actually might pick up by extending the bolt-on ball joint a little further out, so that you can use a dsm axle. It's just food for thought....about the additional negative camber, but that's only speculation on my part.
