It is currently Mon Oct 27, 2025 1:57 am
Post new topic  Reply to topic  [ 55 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sat May 24, 2003 3:15 am
Nobody Important
I need to quit procrastinating and pull the suspension off my 89 gt.
Any chance that car has a wiring harness you want to part with? :)
-paul
PostPosted: Sat May 24, 2003 9:21 am
I plan on using it with a 4g63 swap, but if plans change and i give up the whole idea, i'll post most everything. I would hate to see it crushed with all those good parts.
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Fri May 30, 2003 1:02 pm
I Hit My Rev Limiter A 6700rpm But Thats Because I have A MSD SCI But I Knoe Its Somewhere around 7000rpm :roll:
X2 Hyundai Excel W/ Built Bottom End,Ported & Polished Head, Bored TB, CAI, Venom Ecu & Injectors, Custom Cat-Back Exhaust W/ 5Zigen Fireball Muffler, Apex-i SAFCII, 50 Shot Of NX, R Racing Interior Componets, Stock 13in Wheels, Eurolight Fog Lights!
PostPosted: Fri May 30, 2003 4:31 pm
4g61t Delinquent
hey how do you like the SCI i was looking into getting it.....thats the one with the n2o ignition retard right?
I own a CSM.
PostPosted: Sat May 31, 2003 3:46 am
personaly i think the SCI is really kick a$$ i love the rev limiter because i wont blow up my motor and i still have power all the way to the limiter its a nice unit :wink:
PostPosted: Mon Dec 19, 2005 2:29 am
not positive what RPM the rev limiter is( :( no tach), but it's at 37 MPH in a 4 spd car. I bounce off it all the time autocrossing the car. It's much faster to stay in first and use the limiter than shift and lug the car.
91 Civic Si hatch Autocross star
90 Mazda Miata Sold to friend to become a Spec miata racer
92 Laser RS AWD Needs head
91 Colt 4g15 On 3 cyl. (back on 4 valve looked like pac-man)
90 Eclipse AWD Waiting to give it's motor to a colt
97 Maxima The family car
PostPosted: Mon Dec 19, 2005 5:23 pm
Am I the only one who's taken their 12v above 8k? I've dipped into the 8100rpm range before, and no cut...I think I was super close though. BTW, this isn't a stock motor, but the 1.5 ECU in there. With all the 37 parts on this little motor, she really screams at higher rev levels.
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Mon Dec 19, 2005 8:41 pm
once i got t-boned by a little 4wd in a carb'd suzuki swift, and when i spun into the curb and stopped, i had my foot jammed on the accelerator instead of the brake by mistake (shock etc :oops: ) and the tach needle was bouncing off the 8k stopper. i really dont know how high it was really reving, but it was screaming its 1.3L heart out :twisted:
-91 hyundai excel g4dj->
fully rebuilt, 0.5mm o/s, balanced
diy port & polish,
p&p tb, testpipe
PostPosted: Mon Dec 26, 2005 5:02 pm
7200rpm for my X2 8)
**Hyundai performance**
PostPosted: Sun Feb 11, 2007 11:18 am
Very true Jason. I find with my 4G15 powered car that I need to rev to about 6500rpm to make sure that the 1-2 & 2-3 shifts stay in the power band which is above 4000rpm. Given that, I wound the valve lash in (one good thing about solid lifters) from .15/.25mm (inlet/exhaust) to .08/.18mm which woke up the top end a little to make revving it more worthwhile. I checked compression before and after and it was the same (If they are wound in too far you will loose compression and power).
i know this is old...but important none the less.
on the underside of my hood it says-.06/.10mm (intake/exaust) i found that the valve train has always been noisy. i ran it down to .04/.08 yesterday and it took care of all excess valve noise and have not had any issues at all.
 Post subject: 8 valve vs. 12 valve
PostPosted: Wed Jun 20, 2007 10:47 pm
I'm curious about which numbers apply to the 8v heads and which to the 12v heads. I know some of this was raised earlier
Well from my experience there is no point revving the 4G15 past about 6000rpm unless you have a hot cam in there. I find that changing at around 5800 in my 4G15 Excel drops it smack bang in the middle of the peak in the torque curve. It chirps second with sticky Dunlop rubber when I change at this point. If I go higher, less torque & no chirp & slower.
The 4G15 is an undersquare motor not designed for revs, more for mid-range torque. The 4G61 is very oversquare and hence has low torque but revs to the moon.
Redline on the '93 Excel is at 6200rpm - although this version never made it to the US and is MAP based rather than MAFS.
the version in the excel is also 8 valve and as far as i have seen, no 12 valve motors ever went in them in the U.S. Porting is way different on 12 valve motors. I'm sure the power band would be affected. I believe 12 valve version was introduced in in some 90's and on 91' models.
look in my photo album for comparison pics:
http://photos.yahoo.com/socrateez@prodigy.net
but I'm a little uncertain what applyies to my tired 8v and what doesnt.
red-line (dash tach) is marked at 6000 on my car (90 plymocolt 200gt) and I've always approached that line rather cautiously (she's my daily driver, cant risk screwin the pooch, ya know?), but this threads got me interested in pushing it. in this post,
xlr8 suggest 6500 is optimal. true for a 8v as well? (very stock)
sorry for the ramble :oops:
PostPosted: Wed Jun 20, 2007 10:56 pm
The redline as set on the dash is the redline for your engine. It will not indicate at which RPM you make best torque or HP, but it is the safe range of speed of rotation for your particular engine. That being said, even the factory tachometer has a tolerance, meaning that it is acturate to a point, and may not be properly or accurately/precisely indicating the RPM in the upper ranges.
PostPosted: Wed Jun 20, 2007 11:25 pm
so your saying its not a good idea to pass the factory redline, even if it does keep it in the power band, from a reliablity point of view?
thats whats really important to me. I like to push the car (I think it enjoys being pushed :wink: ) but getting to and from work every day comes first.
PostPosted: Thu Jun 21, 2007 10:52 pm
My old summit had no rev-limiter :P , the mechanical limits of the 4g15 at 9000rpm is about 2 months of hard driving. then the weakest link is the cam which snapped in half. and the retainers tht held them in got stripped out(fukcing aluminum heads). I picked up a new cam out of another csm and some epoxy, and I was back on the road. 2-3 cyl running and all, it lasted another 2 months before meeting the maker. BTW i was trying to kill the engine due to a new 4g63t purchase. So short story, 9000 is the mechanical limit for this car!
4g61t.com
PostPosted: Fri Jun 22, 2007 5:40 am
wow. :o
that is one tough little engine. I feel a little more secure in pushing 6000 now. :D
one question:
was that the 8v or the 12v?
like you said, the cam and top end wound be the weakest link, so it might make a difference.
What I am:
A mopar man with a pervese fascination with fauxpars.
They're just so darn NEAT!! :-?
:o You didnt read anything here.
(something about droids . . .)
