It is currently Wed May 22, 2024 11:30 pm
Post new topic  Reply to topic  [ 50 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: Clutches...
PostPosted: Thu Feb 11, 2010 7:06 pm
i think those aftermarket/high-performance parts offer more than hp, but also more durable in the long run compared to stock clutches since they are made to handle a bit more hp and abuse of use.
You could probably replace a stock clutch 2 or 3 times for the cost of one "high performance" clutch kit.
PostPosted: Thu Feb 11, 2010 8:15 pm
Mikbik, you'll be fine with any ebay replacement clutch for the 4g15.
PostPosted: Thu Feb 11, 2010 8:53 pm
True, but also consider that a heavier plreasure plate will also put more strain on your slave, fork, and thrust bearing; other components may not last with a beefier clutch.
Just something to think about.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Fri Feb 12, 2010 9:32 am
guys what about centerforce clutch they have one for my application and they claim they wont give much pressure coz is it similar or close to stock in weight etc...
PostPosted: Fri Feb 12, 2010 10:48 am
If you have the money to spend on it, go ahead and buy it.
