It is currently Mon Oct 20, 2025 12:40 pm
Post new topic  Reply to topic  [ 36 posts ]  Go to page 1 2 3 Next
 Post subject: FS 89 Turbo Colt Modded
PostPosted: Sat Feb 06, 2010 5:51 am
Up for sale is my heavily modded 89 turbo colt.
Mods:
-block bored .20
-balance shafts removed
-forged pistons big 1g rods
-hastings rings
-bottom end balanced
-head ported and polished
-272 comp cams
-3g lifters
-adjustable cam gears
-plastic intake mani gasket
-mulitlayer headgasket and exhuast gasket
-arp headware
-fuel rail modified with -8 feed and -6 return
-aeromotive fuel pressure regulator
-pte 780cc injectors
--8 an fuel line from tank to high flow filter to rail
-big in tank fuel pump with re-wire
-cyclone dual runner intake manifold, ported and polished
-dnp exhuast mani
-sleeper 20g, evo 3 big 16g machined out with 20g wheels both hot and cold side the exhuast side was clipped
-tubular o2 housing
-ss downpipe 2.5-3
-downpipe back 3" exhuast with magnaflow muffler
-spark tech cop
-custom same side inlet intercooler
-custom ic piping
-3" corvette maft ported and polished with translater
-dsmlink
-kyb agx with ground controls
-energy suspension bushings everywhere
-stailess steel braided brake lines and clutch line
-cross drilled/slotted rotors
-act 2600
-fidanza flywheel
-phantom grip lsd
-bg trans fluid with redline shock adative
-new turbo rad with slim fan
-light weight crank pulley
-nz all amber corners
-piaa high and low beam bulbs
-blossoms body kit
-18" adr
-215/35/18 hankook rs-2 almost 100% front and rear
-new windsheild
-brand new white paint
-full interior not installed
-custom fiberglass gauge mounts with plx wideband, autometer 30/30 boost, electronic oil pressure, volt, and electronis -fuel pressure
-brand new axles and seals
-windows tinted
-apexi avcr
Looking to buy gvr-4 so this toy has to go. I have owned this car for 8 years and put more than I can count time and money into it. This car has been bulit with everything in mind. All gaskets have been replaced with mitsu or equivilant gaskets. You would be hard pressed to find a deal like this. Looking to sell fast. Price is 4500 firm. I am sure there is alot I am forgetting. Any questions just ask.
http://viewmorepics.myspace.com/index.c ... D=13438188
PostPosted: Sat Feb 06, 2010 10:09 am
I wish you were closer....I am selling both my vr4's. I want this car so bad!
PostPosted: Sat Feb 06, 2010 12:51 pm
This thing is soooo tempting..
good luck with the sale!
PostPosted: Sat Feb 06, 2010 1:52 pm
Trade for a super clean 2g shell with motor/trans and a little cash on my end?
PostPosted: Sat Feb 06, 2010 5:50 pm
Sorry guys, not looking to make trades. I found the vr4 I want on vr4.org. Its either this sells or when my tax return comes I will buy it with that. Its already very built and very clean.
PostPosted: Sat Feb 06, 2010 5:56 pm
Keep your CSM and wait til' you get your tax return. Is there any other local CSM owners out your way? Im from NEPA and theres nothing here.
-'92 TSi AWD - Daily driver
PostPosted: Sat Feb 06, 2010 10:27 pm
Very nice colt!!!! good price!!!!
PostPosted: Sat Feb 06, 2010 11:22 pm
epic deal. this car better go to a good home. 4500 is a steal! you beter post up a build thread when you get that gvr4.
PostPosted: Sat Feb 06, 2010 11:42 pm
If I get the one I want, I won't need to do anything but a full suspension. Has 2.4 stroker fully built, fully built trans and rear diff. I am just going to throw a set of tein coilovers, whiteline sway bars, strut bars, headlight conversion, hids, and body kit. Otherwise its already done. I might do a paint job.
PostPosted: Sun Feb 07, 2010 10:13 am
Damn, nice csm man.... Ive got a 92 stealth RT/TTin mint condition with 46k up for trade with a little cash involved maybe if your intrested.... it dyno'd 480 awhp and 470 tq with just a maf-t through a stock catback.....
PostPosted: Sun Feb 07, 2010 2:05 pm
Crazy amount of work on this car....very nicely done! GLWS.
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
PostPosted: Sun Feb 07, 2010 3:48 pm
Dude where do I find a roof rack like that?!?!?
PostPosted: Sun Feb 07, 2010 5:31 pm
Thanks for the comments guys. Like I said no trades, I want what I want. Come on guys, as you can see there is alot into this car. You can also see that nothing was done half a$$ed. The motor was assembled in the summer and body work and paint was done just before winter. The car has 2 miles on it since all the work.
PostPosted: Sun Feb 07, 2010 8:39 pm
Don't sleep on this guys. I just talked to a guy that is willing to fly accross country to look at the car. :supz:
PostPosted: Mon Feb 08, 2010 1:09 pm
I remember seeing pictures of your car years ago and it's still the cleanest CSM I've ever seen. Well done and best of luck with the sale!
Tom
'91 NSX - Sunny days
'99 GSX - Mine
'97 GST - Hers
'03 Trailblazer - Ours
