It is currently Wed Sep 24, 2025 4:59 am
Post new topic  Reply to topic  [ 172 posts ]  Go to page Previous 18 9 10 11 12 Next
PostPosted: Mon Oct 12, 2009 3:08 pm
That would be it.
PostPosted: Mon Oct 12, 2009 3:26 pm
Marck, I don't know what to say other than, I'm glad to be able to see the whole progress of this thing. It's come a LONG way. I remember when you first posted this thread and how I said to myself "this'll never get done". But you stuck it out and you have an AWESOME ride. You've put so much heart and soul into this thing and I can't wait to see videos of it in action. Congratulations man, it looks awesome.
BTW, those Mazda 121's are a Ford Festiva here. I had an 89 Festiva back in the day... :lol: Talk about some gutless cars. I saw one in Florida with a 1.9L HO Escort GT motor and a five speed. THAT was a fast Festiva. Oh, and Jay Leno has one with a mid mounted SHO motor that's absolutely SICK.
PostPosted: Mon Oct 12, 2009 3:55 pm
Digital Baby Troll
The legendary SHO-gun, I've always wanted one of those. Too bad there's only two of the original 6 left and one private built one that Ford dubbed the 7th. By the way truly amazing work Marck. That is one project I could never imagine under going.
-John
89 Mirage Turbo-Money pit
99 Jeep Cherokee-1/4 Epic
01 Cobra-Too Thirsty
72 Dodge-Pedo'van
PostPosted: Thu Feb 04, 2010 3:57 pm
Update guys, finally got the motor on the dyno. Had a serious problem with the OEM Mitsubishi Ignitor, so I could'nt get the engine to run smoothly. Switched to an MSD DIS 4 and got two untuned runs before the rear diff casing cracked. Managed 275 whp @ 13 psi @ 5500 rpm.
Problems now fixed and should be back on the dyno this weekend.
PostPosted: Thu Feb 04, 2010 5:08 pm
Awesome! Big numbers for a 61t with problems. :supz:
PostPosted: Thu Feb 04, 2010 6:07 pm
More whp than a 2.0 Evo X.
PostPosted: Sat Feb 06, 2010 2:50 pm
Which make like 210whp, so like 215?? No bad
PostPosted: Sat Feb 06, 2010 9:13 pm
Got it up to 380 whp at 18 psi @ 7000 rpm, before the boost control solenoid quit. We mapped it to 9000 rpm and got 357 who @ 15 psi (wastegate spring pressure).
PostPosted: Sat Feb 06, 2010 9:19 pm
Very nice!
PostPosted: Sat Feb 06, 2010 11:30 pm
awesome!
throw a manual boost controller on there and be done with it.
also, what is that wood for?
PostPosted: Sun Feb 07, 2010 2:11 pm
Looks like the dyno fan for the rad is hooked in to be aiming into the rad's sweet spot?
PostPosted: Fri Feb 12, 2010 3:04 pm
This was a 14.5 psi dyno run. I was unable to capture some of the higher rpm runs, but the power and torque pretty much follow the same trends as you can see below. The difference between the two is due to some minor changes in timing and fueling that we were experimenting with.
Making more whp than a stock Evo 4-10 makes at the flywheel, with less boost. And it's only 1.6 liters.
PostPosted: Fri Feb 12, 2010 4:58 pm
You need to rev that thing to like 9,500
PostPosted: Sat Mar 13, 2010 8:28 am
First shakedown test drive.
http://s30.photobucket.com/albums/c313/ ... ession.flv
PostPosted: Sat Mar 13, 2010 11:04 am
Nice! :supz:
