It is currently Tue Oct 28, 2025 1:37 pm
PostPosted: Mon Jan 18, 2010 1:50 pm
How do I know if my Maf and TPS is busted? I have a 4G15 8valve engine..thanks
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
PostPosted: Mon Jan 18, 2010 2:06 pm
x2
Except mine is a 12v
PostPosted: Mon Jan 18, 2010 3:07 pm
Both of those sensors will throw a check engine code
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Mon Jan 18, 2010 5:56 pm
yup i have a check engine code:
the scenario:
after puting the key to ON position the check engine goes off after 5 seconds then start it after then cruising for about half mile the check engine goes ON again. One more thing is my idle doesn't go up during cold start but when I tested the idle switch motor manually its working fine.
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
PostPosted: Mon Jan 18, 2010 8:41 pm
i dont have my o2 sensor unplug, because i have a new down pipe w/o o2 sensor. So my check engine is always on.
Could ther be any more signs other then "Check Engine" light? :lol:
PostPosted: Mon Jan 18, 2010 8:57 pm
It would have other codes besides the O2 sensor code. Perhaps you should hook up the O2 sensor and then see if there's anything else in need of attention.
PostPosted: Mon Jan 18, 2010 11:31 pm
I have no idea where that o2 sensor is now. The down pipe does not have a hole for it to be put in.
PostPosted: Tue Jan 19, 2010 1:35 am
You need to buy a hole (they're like $7.00) and weld it in. Then buy a sensor, and install it. Your car's never going to go into closed loop operation without the O2 sensor.
PostPosted: Tue Jan 19, 2010 5:02 am
how much for the O2 sensor sir?
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
PostPosted: Tue Jan 19, 2010 8:54 am
Probably $60 and worth every penny if you need one.
PostPosted: Tue Jan 19, 2010 11:00 am
I dont understand this sir? Closed loop operation?
PostPosted: Tue Jan 19, 2010 8:59 pm
Engine cold and maybe the first minute of operation = open loop = just dumping in fuel based upon fuel map tables.
Engine warming up, after first minute of operation and when 02 sensor is hotter = closed loop = more controlled air/fuel ratio at all times but WOT when preset values are used again.
PostPosted: Wed Jan 20, 2010 12:55 pm
Awe ok i got cha. Thnks bro :supz:
You sum things up really easy
