It is currently Tue Oct 21, 2025 10:10 pm
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: New beater car.
PostPosted: Tue Dec 08, 2009 8:19 pm
Unless there is someone here from Richmond, IN.
PostPosted: Wed Dec 09, 2009 3:49 am
I bought the car knowing it had blown turbo but I also found out there is a problem with the brakes locking up. I have a 14b that I'm going to throw on the car and now an new manifold because the stock one is cracked. Tonight I got started on pulling the turbo, I ended up breaking two bolts from the turbo to manifold and finding out the the stock manifold needs replaced. I also found out why the stock turbo was locked up. And I plan on painting the valve cover, lol.
wft, really
broken bolts
manifold cracks
PostPosted: Wed Dec 09, 2009 5:01 am
wow, wtf! My 61t manifold cracked also in the same place in the middle. What manifold are you replacing it with? 2g mani or better is what you need! goodluck
My feedback thread:
PostPosted: Wed Dec 09, 2009 10:37 am
Hopefully that bolt isn't all cross threaded and ghetto'd into the head. Jeez, some people :rolleyes: .
PostPosted: Wed Dec 09, 2009 11:18 am
Looks like the factory bolt for non turbo cars. My guess is that they replaced the head with one from a non turbo car.
PostPosted: Wed Dec 09, 2009 12:52 pm
OMG man that is so funny but at the sametime so unfunny ha hai think i got a 1g and a 2g ex mani laying around pm me if you need anything!!!
PostPosted: Wed Dec 09, 2009 1:11 pm
I may need a manifold, I just gave my buddy my 2g ported like 2 weeks ago. :x
PostPosted: Wed Dec 09, 2009 1:45 pm
just pm when the time comes!!!!
PostPosted: Wed Dec 09, 2009 2:10 pm
They probably plugged the oil feed after the turbo died so it wouldn't smoke... Or at least I've been known to carry that same bolt around in a car that the turbo was going out on :oops:
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Dec 09, 2009 5:03 pm
^lols^
And thanks for the offer but I already found one!
PostPosted: Fri Dec 25, 2009 1:03 am
So I have made a little progress. I got the turbo off, engine bay clean, and the valve cover prepped for paint. I also looked at the brakes and it looks like one of the rear calipers was locked up, I got it off just need some money the rear calipers are around $100 :shock: . I also got all my gaskets, hardware and spark plug wires. The only thing holding me up now is two broken manifold studs, I can't fit a regular drill so I will have to get a right angle drill to get in there.
PostPosted: Fri Dec 25, 2009 11:31 am
Pull the radiator for more room.
PostPosted: Sat Dec 26, 2009 8:49 am
Yes, what 89mirageman said is correct. If you pull the radiator, you'll have the room to get in there with a drill.
Best of luck!
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Sat Dec 26, 2009 11:28 am
Come on now, of course I pulled radiator. The condensor is in the way now and I don't want to drain the ac line.
PostPosted: Sat Dec 26, 2009 12:16 pm
break the drill bit in half. = shorter drill.
