It is currently Thu Jun 06, 2024 10:01 pm
PostPosted: Thu Oct 01, 2009 10:23 am
Hi again guys
just a quick look around for some uprated parts for the awd conversion im doing
is there any uprated transmission LSD's & rear axle diff ?
iv been looking around but as this is the first we doing a 4x4 swap im not sure what to look for and if im looking for the right things
this is the car im using for the conversion
the rear subframe is from a 1990 Mitsubishi Galant GTI 4WD & 4WS
If anyone has any ideas of where i can go or what will fit then please get in touch
any help with this is mucho appreciated
pics of the car below
mike
MPH now have our own forum for new and existing customers to view all our development parts and our R&D service
http://mphperformanceforum.co.cc/
PostPosted: Thu Oct 01, 2009 10:58 am
Hi again guys
In the states, Galant VR-4's never came with an LSD rear diff because they had 4WS. As far as I know, none of the N/A 4WD Galants like the Galant GSX had an LSD in the rear either. You would have to swap over to Eclipse drivetrain parts, but then your gearing is not going to match and you'll blow up your center diff in a hurry. Since you're in Europe, you may be able to use early EVO bits, but I'm really not sure.
PostPosted: Sun Dec 06, 2009 8:53 pm
Hi again guys
Not sure if the diffs are the same or not, but if they are then you could just put the proper gears in a LSD rear end.
PostPosted: Fri Dec 11, 2009 11:22 pm
Wow, I want your parts car, lol.
-'92 TSi AWD - Daily driver
PostPosted: Fri Dec 11, 2009 11:30 pm
will soon be scrapped as its now stripped off all the parts and is a bare shell
parts not needed for conversion will be up for sale as of tomorrow
as for the project we have been busy so its took a back seat while customers cars are finished, after christmas we will really make a start on getting the 4G63T VR-4 engine we have fitted and the AWD setup fabricated and installed
PostPosted: Sat Dec 12, 2009 2:43 pm
www.galantvr4.org
Search those forums, or ask in the Newbie section and tell them you are just passing through.
Lots of information about differential options, and which gears fit into which axle setup.
PostPosted: Sun Dec 13, 2009 5:47 am
http://www.galantvr4.org
i hate that forum software so much.
