rebuilt both calipers, same thing! I'm not sure what's going on now. There shouldn't be a problem with elantra master cylinder and galant vr4 big brakes? I bleed both sides, the pedal doesn't seem to be very stiff on the top either. Anyone have ideas? I can also hear what's sound like air when i push in the brake pedal? This isnt making much sense, sounds like it's coming from the pass side.
That sound you hear is the master cylinder compressing. They are on the right side on these cars, as im sure you are aware. Make sure both slider pins are clean and smooth. If they are hanging up than they will not allow the brake to return once you're off the pedal. Do you have the vaccuum line running to the booster? There should be a one way valve going to the back of the throttle body. Might want to make sure that its installed correctly. I doubt that would be the cause of your problems but its worth checking into.
