It is currently Sun Oct 19, 2025 10:59 pm
PostPosted: Thu Aug 06, 2009 11:07 pm
Basically what the title states. I'm wondering if they are exactly the same. For when I swap my Colt and change it from cable to hydraulic I want to know so I can search for the parts little by little.
PostPosted: Fri Aug 07, 2009 3:40 pm
i assume your talking colt
if so the i believe.... there very similar but im not 100% sure half to wait some more info
PostPosted: Fri Aug 07, 2009 4:23 pm
No the master is not the same, the slave is minus the rod as they are the same in most mitsu's of that time. I thnk the lines may be workable too, and have no idea about the peddles.
PostPosted: Fri Aug 07, 2009 5:14 pm
yes I mean Colt.. lol. Well I would be installing a DSM FWD transmission in it for when I do the 4g63T swap. I was actually thinking about doing the 2.4 hybrid (4g64 block/4g63 head). I mean if I'm swapping, why not go all out? I would be using the DSM slave cylinder anyway.
Maybe I can just source a new master cylinder from an auto store and just piece it together myself. The tough part to find would be the pedal assembly assuming its different between cable and hyrdaulic.
