It is currently Wed May 29, 2024 2:32 am
PostPosted: Thu Jul 16, 2009 1:51 pm
i have a awd swap in my 92 mirage.
the only thing left to work out is the brakes. it seems like they are grinding in the front. it has new pads and rotors. but still the same thing. any ideas
PostPosted: Thu Jul 16, 2009 8:18 pm
did u check to make sure the backing plate isnt rubbing? they get bent easy.
PostPosted: Thu Jul 16, 2009 8:51 pm
I am guessing that you are using the stock rotors, hubs, and calipers?
PostPosted: Thu Jul 16, 2009 10:10 pm
yes it is all stock awd talon everything. it is very crazy it is only grinding the back bottom of the rotor. but very badly. and this is with new rotors and pads
PostPosted: Thu Jul 16, 2009 10:13 pm
could bad alignment make this happen? i realy dont think so but i dont now what to think anymore. went over it and it is all tight no cracks int he mounts and as fare as i can tell the caliper is not bound. could a stock mirage master do something like this. i really dont have a clue what to do next so any help would be great
PostPosted: Fri Jul 17, 2009 8:15 am
The wheel alignment will have nothing to do with how the brakes function. Sounds to me like the caliper may not be centered on the rotor. There was a write up somewhere mentioning that some spacers would need to be used to center the caliper if swaping over to dsm brakes with out changing the hubs. Just going by memory, it was a long time ago that I read it.
Take some pictures if you can and post them up, :D might help out some more.
PostPosted: Fri Jul 17, 2009 8:30 am
i have the awd hubs from the talon to. the hole setup was of the same car and the car sat for a year befor i swap it to my mirage.
i will take some pics today
thanks
PostPosted: Fri Jul 17, 2009 4:17 pm
Did you swap everything, from the ball joint up, knuckles too. If that is the case, then there is no reason why everything won't work. My brakes work awesome with the stock colt master cylinder. The grinding is warped rotors/ improperly installed pads, etc. I didn't even install new brake pads when i did my swap, that would break my budget.
PostPosted: Fri Jul 17, 2009 10:56 pm
so i found it. the slid bolts that the caliper rides on are bent. took some off my tsi and the brakes work gret now. thanks for all the help. and man they work great now. i love this car more and more :supz:
