NEWBIE's been kicked out of class. I thought that this "Newbie Tech" area was for Newbie's to ask dumb question's. Guess my questions weren't dumb enough. Please consider your problem solved, as questions in engine mgmt (or any other questions) are more that happily answered by the
hoard of 'kids' in the HONDA CRX forum's (where I came from).
FWIW I don't have the cubic hours to research these "TON's" of threads and "Other" forums. It took you what....45 seconds, to pitch your bitch and then answer my question. You could have just answered the question in 20 seconds. I've spent hours reading this forum to get this far. Guess I'll just continue reading, as I refuse to let your attitude get me down in my effort to build a Vette kicking Colt.
Trying to get my head on straight as far as various controls needed to keep my engine in one piece. Can the Apexi SAFCII be used with my ECU ('89 4G61t) for controlling larger injectors (750cc). With that type of controller, does one still need something like a UEGO CONTROLLER 30-4100 (wideband), and then also a EGT, for proper tuning, or does the Apexi provide some of these functions......The more I learn, the more I don't know......Byron
Dude, you really need to spend some time searching around instead of just making a new thread every time you have a question. There are tons of threads on here, and on other forums dealing with these exact same questions.
Yes you can use an SAFCII with your 4g61t ECU. Yes, you should get a wideband to aid with the tuning, and no, the SAFCII doesn't support an EGT, you would need to get a seperate EGT.
