It is currently Mon Oct 20, 2025 12:41 pm
 Post subject: Motor & Trans Mounts
PostPosted: Thu Jun 11, 2009 8:47 am
Hi All,
My 21-year-old engine and trans mounts are getting a little sloppy. I'd like to replace all of them with Energy Suspension or Prothane ones. If you have done it with either ES or Prothane, please advise on part numbers and where to buy them. I can go with OEM ones if nothing else is available.
Thank you!
 Post subject: Re: Motor & Trans Mounts
PostPosted: Thu Jun 11, 2009 10:14 am
window weld my friend works pretty good
PostPosted: Thu Jun 11, 2009 1:24 pm
Please elaborate as I have never heard of window weld before. If it works, I'll try it!
_______________
PostPosted: Thu Jun 11, 2009 3:58 pm
go to advanced auto or your local parts house
its a black tube like a caulk tube
rap the mounts in tape (after youve clean them)
and squirt the window weld into the empty spaces
PostPosted: Thu Jun 11, 2009 6:36 pm
Thank you for the info. I'll get some asap!
___________________
PostPosted: Thu Jun 11, 2009 7:33 pm
i will recommend to you only put those mount in the front and back of the engine, dont put them in all 4 corners or the whole car will rumble :o
