It is currently Tue Jun 04, 2024 6:01 pm
 Post subject: LIL EVO, 2009
PostPosted: Thu May 28, 2009 7:04 pm
Time for a quick update on the car (1990 Mirage). The engine is done and ready for pick up tomorrow. Eagle rods, Ross 8.3:1 pistons, fresh stock head, 272/272's, Felpro Permatorque gasket, ARP head studs. Same turbo, GT35R.
I also purchased Kiggly's HLA regulator
http://www.shop.kigglyracing.com/produc ... roductId=7
Brakes:
Installed 4 fresh wheel bearings and the Wilwood 4 pot Chris Burns big brake kit.
http://lilevo.com/lilevo2/wilwood/final.jpg
http://lilevo.com/lilevo2/wilwood/rotors3.jpg
http://lilevo.com/lilevo2/wilwood/rotors2.jpg
I ordered two 28" stainless lines for the rear calipers and mounted them somewhat stock. I was running rubber lines.
http://lilevo.com/lilevo2/brakes/RLbrake.jpg
http://lilevo.com/lilevo2/brakes/RRbrake.jpg
Furthermore, I installed a 2G turbo 15/16" master cylinder and a 93 T/E/L proportioning valve. I needed to custom bend one brake line and re-flare it, but for the most part it bolted right up. I'm very excited to test the new brake setup out.
http://lilevo.com/lilevo2/brakes/mc1.jpg
http://lilevo.com/lilevo2/brakes/mc2.jpg
http://lilevo.com/lilevo2/brakes/propvalve.jpg
Fuel:
I purchased a Walbro 392 inline pump and 1150cc injectors for the new setup. The inline pump is currently operated by a switch in the center console, but I may change that to turn on with a pressure switch at a certain boost level. LED in dash to tell me when it's on. I ran -6 from the in tank pump, to the inline, to the hard fuel line. At that point, I said screw it and added 9 additional feet of -6 from the inline pump right to the Fuelab filter in the engine bay and bypassed the stock hard line. I also have a -6 line from the Fuelab filter into the rail.
I installed two relays in the trunk which feed off a stock T/E/L battery fuse box. I rewired everything so 10 gauge is essentially running from the battery + and - to each fuel pump.
You can also see my "custom" fuel pump harness connector. I removed all blade terminals and soldered 10 gauge to everything.
http://lilevo.com/lilevo2/fuel/fuelab.jpg
http://lilevo.com/lilevo2/fuel/pump1.jpg
http://lilevo.com/lilevo2/fuel/relays.jpg
http://lilevo.com/lilevo2/fuel/relays2.jpg
Other:
I installed an MSD DIS 2, JDM indicators, I will be installed a FMIC sprayer with EVO3 IC sprayer nozzles that came on my E3 bumper.
Once I somehow get a couple thousand miles on the new motor I'm heading down to Illinois for some dyno tuning with Mike Reichen and Yusuf.
...C16
...40psi
More to follow
 Post subject: Re: LIL EVO, 2009
PostPosted: Thu May 28, 2009 7:29 pm
Yusuf is the man! I'm running that dude's old transmission in my GSX as we speak. Good luck with the build, sounds like it will be a sick setup when it's all done. Can't wait for more pics and vids.
PostPosted: Thu May 28, 2009 9:23 pm
Forgot to include my breather/catch can/recirc drain.
Two -10 off the valve cover to a catch can, -12 from the catch can to intake tube, -6 drain back into the block.
Stock PCV system into a second catch can
http://lilevo.com/lilevo2/engine/breather.jpg
PostPosted: Fri May 29, 2009 8:29 am
Oh boy. Sounds like so much fun. Gonna be at the shoot-out?
PostPosted: Fri May 29, 2009 11:38 am
so sick keep it coming man.
o can you elaborate on the Kiggy Racing HLA Pressure Regulator. i know where it is on the head but dont know to well as to what is dose?
PostPosted: Fri May 29, 2009 3:47 pm
The HLA regulator keeps the pressure in the head to 15psi. The cams and turbo are a separate feed.
From what he told me, it helps keep oil in the pan where it needs to be at the end of a quarter mile pass. It also does some other things like bleed off air at the highest point and keep the lifters happy so there is less chance of rockers popping off and such.
The idea is that by the end of a quarter mile pass or long pull, there is a lot of oil pooled in the head that should be down in the pan.
Hope that helped.
PostPosted: Fri May 29, 2009 4:20 pm
Kind of like the jdm motor's spring relief, kiggly just uses a restrictor instead of the spring though.
PostPosted: Wed Jun 03, 2009 12:42 pm
Man that is going to be a quick car. Keep it going Jason..!
PostPosted: Fri Jun 05, 2009 1:39 am
I installed a 2G washer fluid bin in the trunk for my EVO3 intercooler sprayers. I suppose it can also be converted for meth/water injection.
http://lilevo.com/lilevo2/fmicspray/fluidres1.jpg
http://lilevo.com/lilevo2/fmicspray/fluidres2.jpg
I also rigged the stock cluster low washer fluid bulb to come on when the FMIC sprayer is empty. Neat huh? :)
http://lilevo.com/lilevo2/fmicspray/lowlite.jpg
I installed a Hobbs pressure switch to turn on the second fuel pump and FMIC sprayer at 23psi automatically. An LED in the dash also illuminates to tell me that they have been activated.
Walbro 392
http://lilevo.com/lilevo2/fuel/392.jpg
Pictures of the engine so far
http://lilevo.com/lilevo2/engine/engine ... neback.jpg
http://lilevo.com/lilevo2/engine/engine ... efront.jpg
Rear balance shaft, milled down.
http://lilevo.com/lilevo2/engine/engine ... shaft1.jpg
http://lilevo.com/lilevo2/engine/engine ... shaft2.jpg
Brand new OEM front cover and oil pump gears
http://lilevo.com/lilevo2/engine/engine ... tcover.jpg
http://lilevo.com/lilevo2/engine/engine ... cover2.jpg
PostPosted: Sat Jun 06, 2009 9:38 pm
It runs!
http://lilevo.com/lilevo2/videos/2009/l ... t_2009.wmv
PostPosted: Sat Jun 06, 2009 9:49 pm
Good work 8)
PostPosted: Wed Jun 10, 2009 12:31 pm
Awesome Jason. How much longer till you drive it?
PostPosted: Wed Jun 10, 2009 1:51 pm
Been driving it all week! Have 80 miles and an oil change on it so far
PostPosted: Thu Jun 11, 2009 10:16 pm
Brakes look good. I wanted to buy that other set for the galant but money was tight at the time. Anyway, its always great to see lilevo updates.
PostPosted: Thu Jun 18, 2009 6:32 pm
I was wanting to ask how do u like ur new brakes by the way. Did u do any brake testing like times befor with the old setup and stoping times with the new? Just thought I would ask.
Tyler,
