It is currently Sun Oct 19, 2025 10:50 pm
 Post subject: degree of compression ??
PostPosted: Sat May 09, 2009 5:58 am
You know the degree of compression of the engine 4G32 Turbo because the turbo will change with great?? to figure out how to reduce the degree of compression
PostPosted: Sat May 09, 2009 9:36 am
7.8:1
PostPosted: Sat May 09, 2009 9:52 am
You can use a thicker head gasket, or remove material from the combustion chambers. The latter method is more difficult.
PostPosted: Mon May 11, 2009 12:05 pm
10x guys
PostPosted: Tue May 12, 2009 3:33 pm
when you use the thicker headgasket. keep in mind it directly effects the timing.
