It is currently Sun Oct 19, 2025 7:51 pm
PostPosted: Wed May 06, 2009 7:19 am
Does anyone know how to repair the intermittent setting on the wiper? I took the whole thing apart, cleaned all the contacts, put it back but the thing still not working. Other settings (setting1 and setting2 and the rear wiper) work just fine.
If you are parting out your car, please let know so I can get the whole wiper switch to play with.
Thank you!
____________________
PostPosted: Wed May 06, 2009 8:02 am
If there is no issue with the wiring then getting a new stalk is the next logical step.
PostPosted: Sun May 10, 2009 10:20 pm
do you have an intermittent control installed??? chk your realy
PostPosted: Mon May 11, 2009 7:33 am
I will check the relay. Thanks for the tip!
_______________________
PostPosted: Wed May 27, 2009 7:35 am
The problem is fixed! It turned out to be the wiper relay as stated by Miragesist. Thank you so much Miragesist! I bought a new relay from Rockauto.com part number RY103 for $11.30, put it in and now my intermitten is working just perfectly!
___________________
PostPosted: Wed May 27, 2009 7:43 am
That's good to hear! Pretty awesome how cheap the part was too.
