It is currently Wed May 22, 2024 10:40 pm
PostPosted: Wed May 06, 2009 6:12 am
looking for information or some help as to how i fit the 2pot brakes and hubs sucessfully without the nasty camber issues...
PostPosted: Wed May 06, 2009 6:17 am
Grind down the top of the knuckle where the strut and knuckle bolt together and slot that top bolt hole in the strut. It will allow you to remove the positive camber. Or you can get camber plates.
PostPosted: Wed May 06, 2009 9:44 pm
This guy shows you how to use the stock csm captive setup by converting it.
http://www.4g61t.org/forum/viewtopic.php?f=10&t=24309
