It is currently Sun Oct 26, 2025 9:34 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
 Post subject: stroker motor
PostPosted: Mon Mar 09, 2009 3:42 pm
Hey so this might seem like a really stupid question to most you but what is a "stroker" motor? Or i guess I should say what is the difference between one and a stock motor?
 Post subject: Re: stroker motor
PostPosted: Mon Mar 09, 2009 4:30 pm
Only differnce between a stock and a Stroker motor is just a few letters
PostPosted: Mon Mar 09, 2009 8:15 pm
a stroker is when you put a larger crank in a motor giving the rods more "stroke" there for being able to produce more power. in a 4g63 it would be a hyundai 2.4 crank in a Mitsubishi 2.0 making it a 2.3l. or in a small block chevy, a crank from a 400ci motor into a 350ci motor which makes it 383 stoker.
PostPosted: Mon Mar 09, 2009 8:18 pm
2.0L 4g63 = 85mm bore x 88mm stroke
2.3L stroker = stock-ish bore x 100mm stroke (4g64/g4cs crankshaft), in a 4g63 block
2.4L stroker = 87mm bore x 100mm stroke (4g64/g4cs crankshaft), in a 4g64/g4cs block
The stroker motors use stock-length 4g63 rods, but require custom pistons which most aftermarket piston manufacturers (JE, wiseco, CP) carry on-the-shelf. Most people opt for the 2.3 because it's slightly cheaper considering you don't have to source a different block, and using the 4g64/g4cs block requires machine work if you want to run oil squirters.
PostPosted: Mon Mar 09, 2009 9:05 pm
if your thinking about 1... I have 1 for sale..no shipping as we live in same town lol..I have a f/s posted for it with pics.
PostPosted: Mon Mar 09, 2009 10:33 pm
There's a 2.1 as well.
PostPosted: Mon Mar 09, 2009 11:11 pm
That's a de-stroker :wink:
PostPosted: Tue Mar 10, 2009 1:11 am
Negative Nancy
But a 400 with a 350 crank would be a 377....Kinda weird HUH.
PostPosted: Tue Mar 10, 2009 1:47 am
but they also bore it out..
PostPosted: Tue Mar 10, 2009 1:52 am
Negative Nancy
Exactly!!!!!!
PostPosted: Tue Mar 10, 2009 3:13 pm
My bad. It's still bigger tho. :D
PostPosted: Wed Mar 11, 2009 6:22 am
move to newbie tech...
PostPosted: Thu Mar 12, 2009 1:14 am
so other than more power, are there any major advantages or major disadvantages to building or running a stroker motor?
PostPosted: Thu Mar 12, 2009 1:17 am
Negative Nancy
Headache :yawinkle: Wait till you get the head worked on and go with insane cams. Then your back yard machine shop tells you that Cletus thought it be better to go .4356 oversize cause Manerd did the same thing in his 74 duster and he's runnin in the low 14's on his G-Tech from the pawn shop.
Dick
PostPosted: Thu Mar 12, 2009 5:52 pm
More torque and more power mainly from the cubic inch increase, downside is that it can't rev as high.
