It is currently Mon Nov 03, 2025 12:46 pm
Post new topic  Reply to topic  [ 38 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Feb 11, 2009 12:35 am
http://www.youtube.com/watch?v=KUFFudEJnjk
PostPosted: Wed Feb 11, 2009 2:27 am
that shit is sick, really nice setup. i think thats the most hp ive heard coming out of a s2000.
PostPosted: Wed Feb 11, 2009 7:29 am
Has to be the most. But I doubt its stock internals, maybe stock with thicker head gasket maybe but not on stock compression.
PostPosted: Wed Feb 11, 2009 7:56 am
question is how longs the rear gonna hold? i've seen stock units take a dump at the track with just drag radials.
PostPosted: Wed Feb 11, 2009 10:39 am
He claims a 100% stock bottom-end.
PostPosted: Wed Feb 11, 2009 11:27 am
thats one sick s2k! wonder how it compares to the swapped 2jz s2000's?
PostPosted: Wed Feb 11, 2009 12:07 pm
The 2jz is always gonna make more torque, but it will make the car heavier.
PostPosted: Wed Feb 11, 2009 2:12 pm
I am usually not a fan of Honda's, but this thing is pretty sick.
PostPosted: Wed Feb 11, 2009 3:19 pm
It's so hard to impress Tony. That's the impressive reality! :P
Very hard to imagine the drivetrain is that strong....but I wouldn't know for sure. That car is wicked!
PostPosted: Wed Feb 11, 2009 3:41 pm
1595 cc's of fury
Its either not stock, or won't run for long. The s2k's are impressive but severly lack strength. One hard launch with that kind of power will break the either the rear end, axles, drive shaft, trans...or a combination. I've watched several stock ones break rear end's and axles at the track with DR's and traction.
Also the power band isn't very impressive, it takes way to long (even at higher boost) to get to 150 mph. He barely beat the 600 and the 1000 was gone. That just seems slow, even if he was only at 600 whp, the Widow vs a modded R6 and 636 wasn't even a competition (probably 6-8 car lengths from 60 - 140) and it makes much less whp and is at a similar weight now.
Still, I've always wondered why there arn't more bad ass S2K's on the streets...
PostPosted: Wed Feb 11, 2009 3:56 pm
This is how you take out a liter bike....http://videos.streetfire.net/video/Outl ... 184260.htm A local 2g....
PostPosted: Wed Feb 11, 2009 4:43 pm
Im not impressed, I built all motor Hondas that can woop an R6 more than that. Probably more like a 400whp S2K.
PostPosted: Wed Feb 11, 2009 4:45 pm
the only thing saving that motor is the turbo not being in its peak effiency because a s372 at 8 psi or even 18psi isnt shit for that turbo
PostPosted: Wed Feb 11, 2009 5:02 pm
So its the classic strap on a big ass turbo without doing the research to mate the engine with the best turbo for flow/efficiency....
PostPosted: Wed Feb 11, 2009 6:02 pm
Well they say in the description that it wasn't making 701whp when they filmed it, so at 18psi it's very possible that he was only in the 400whp range.
According to lots of my Honda buddies, there are many cases of guys running 600+whp on stock internals, but the fact that he's doing it on stock drivetrain is sort of unbelievable. As far as weight, S2K's are up around 2,800lbs from the factory IIRC.
