It is currently Mon Oct 20, 2025 6:11 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
 Post subject: Re: 90 colt...4g61t
PostPosted: Tue Feb 03, 2009 10:13 pm
Is this the same car that is currently for sale on craigslist?
http://asheville.craigslist.org/cto/999263776.html
Looks like it to me, wonder if he decided to keep it?
PostPosted: Wed Feb 04, 2009 2:45 pm
i bought the car from that guy.
PostPosted: Wed Feb 04, 2009 2:54 pm
That explains it. Just making sure someone wasn't listing your car. There are scams on Craigslist all the time.
PostPosted: Thu Feb 05, 2009 2:04 pm
I'm curious to know though, he says it is a 4G61T in the car, and in the Craigslist ad it says he has a MLS head gasket. I thought that there was not a MLS head gasket made for the 4G61T?
Also, what roll cage is in your car? I am very interested to know... thanks! :)
PostPosted: Thu Feb 05, 2009 2:58 pm
There wasn't. He's probably using a 4G63 MLS head gasket.
PostPosted: Thu Feb 05, 2009 4:59 pm
You can do that? I thought that doing that is unsafe or wouldn't work right. Interesting...
PostPosted: Thu Feb 05, 2009 5:04 pm
It's been brought up many times on here, and I think the general consensus was that you could do it, but I'm not 100% sure.
PostPosted: Thu Feb 05, 2009 5:16 pm
You can do it, but it will drop your compression ratio by the amount of shelf that is created, which is also a shelf for carbon to deposit and create hot spots with or other problems associated with swirl, squish or whatever head and piston designs are built into this motor. People that have tried it, report no issues, but how long were the motors used for, and were they experiencing problems and not realizing it, no one can really pinpoint with scientific data to back it up.
Best idea is the use the proper sized gasket and some good ARP style studs. The factory gasket with proper mating surfaces (ie flat) is a great way to go on lower boost applications < 25 psi (my theory, not from experience). The only problem is that the 4g61t has no MLS gasket, although it would be identical in construction, with a different bore sizing.
I preach using the proper part for the job, on principle, knowing that people can use the other incorrect but functional part, is the other way to go, but at the users discretion. :wink:
PostPosted: Thu Feb 05, 2009 6:36 pm
it is a weld-in 6 point roll cage, i think it was made by cia.
