It is currently Sun Oct 19, 2025 7:53 pm
Post new topic  Reply to topic  [ 56 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: 86 colt update
PostPosted: Thu Jan 15, 2009 10:00 pm
the dsm bumber is on. it was a pain but it worked. i am useing fiberglass to flare the finders. i even made brakets so that the bumper bolts up and is easy to remove. it looks really good.
PostPosted: Thu Jan 15, 2009 10:26 pm
:pics:
PostPosted: Fri Jan 16, 2009 11:39 am
nice work, keep it up and post those pics, and don't worry too much about the layoff, it happens - keep looking forward. :alright:
PostPosted: Fri Jan 16, 2009 8:35 pm
ok here is a older one when i was first messing around with it. i have now just about finished up with a fiberglass grill. i will post it as soon as i get the picture off my phone.
i really have no idea what i am doing with these pictures!!!!!
**Pic fixed by Evotistical**
PostPosted: Fri Jan 16, 2009 8:40 pm
Fixed!
PostPosted: Sat Jan 17, 2009 12:09 am
thanks, can you fix these ones also. these will show the grill, and how i am flaring the finder to match the bumber. i am useing fome, then sanding, then coverring with fiberglass. then i will bondo, sand again, then paint. its really starting to look a lot like a car.
like i said i cant do it any other way so if some one can fix these then thanks.
** Pics fixed by evotistical**
PostPosted: Sat Jan 17, 2009 1:44 am
Fixed again!
PostPosted: Sat Jan 17, 2009 10:19 am
you are just a picture fixing whore arent you :D
i think it looks cool as shit keep the picture coming
PostPosted: Sat Jan 17, 2009 10:58 am
wow, you turbo'd the 1.5? thats different!
you got it to fit alot better then i thought could be done. the fenders, and it being to wide made me just decide to find something that would fit better. also, the dsm bumper is curved pretty bad were it meets the headligths, and grill. and my 88 is straight across, and left a massive gap. just wasnt worth the work to me.
but mad props to you for going through with it. looks like you have done alot to your car.
PostPosted: Sat Jan 17, 2009 11:39 am
His car came with a 1.6 g32b turbo. not a 1.5 g15.
PostPosted: Sat Jan 17, 2009 2:01 pm
yes it is a g32b, and thanks. there is still a lot to be done, the gaps will all be filled and that will be part of the grill work. i am taking it kinda slow, one step at a time but like i said its really coming together. now if i can get a exhaust manny, with a wast gate flang i will be good to go. whats up trev tech, tobby still going to sell that thing???
PostPosted: Sat Jan 17, 2009 2:31 pm
how is your intake set up then? since yours is on the side, instead of facing the front. it through me off.
PostPosted: Sat Jan 17, 2009 3:28 pm
there is a 90 coming right off the tb.
PostPosted: Wed Jan 21, 2009 11:17 am
ok so now i cant figure whats up with my shifter. i pulled the boot to get a look at what was going on in there and what do i find? nothing at all. a hole. yes the shifter runs under the car and all the cables run under the car to the trany. now my question is this. what trany do i have, and has any one done any mods to this set up. i was hoping to do a short shift but now its not looking like i can.
PostPosted: Wed Jan 21, 2009 12:06 pm
are trans code is either
km162, 172, or 182
there is no short shifter for our car but....... (there is always a but)
if you pull the shifter out the bottom (yes thats how it comes out) by the 2 or 4 bolts on the floor around the shifter. Then disconnect the linkages on the trans. and if you cut the shifter right below the swivel ball and add a piece in there you will have made a short shifter if you want ill do mine then post pics.
Deco give me a call if you have any questions
240 848 6662
BTW i order my pistons and gasket kit all i need now is a 4g63 harness and odds and ends stuff
