Why would I need to put the intercooler at an angle, if i'm at the further point right now? The bottom is as far back as it can go. I'm going to try to make the summit bumper fit without the crash beam.
Worst case.. I will change the intercooler design.
http://www.4g61t.org/forum/viewtopic.ph ... 27#p178527
^^Ben's FMIC setup is by far the best I've ever seen in a CSM. If everyone did their's this way, these cars would be able to retain their factory looks and still have a decent intercooler setup. If you want to try to run the Summit bumper, you will literally have to take everything out of the front and make the bumper cover an empty shell.
. That core was actually made by ETS.
