IF..IF the mpi Relay is going bad/Or is not bad,I'd still like to change it to be on the safe side.
In my experience, they either work or they don't work. There's no "going bad", but I guess it's possible. It is also possible to have a bad ECU without having leaky caps. I was running an ECU for a while that would do exactly what you're describing and the caps looked perfect. Car would barely run, and there would be tons of clicking from inside the dash. The clicking you're hearing is the MPI relay turning on and off, I beleive it's the relay that controls the power of the ECU.
So where Can i buy a MPI relay guys?
You have to buy it from Mitsubishi, or go to a junkyard and find one. I don't know if the turbo ones are different.
Can anyone show me a picture of where its located?
It's way down inside the dash, you'd pretty much have to take everything apart to get to it.
Wait,Would a MPI relay cause my car to shut off the engine,Or would it cause my ENTIRE car to shut down meaning lights and all? Because what i noticed was that sometimes it Shuts off the car,Meaning no lights,Wouldnt an MPI relay Only Control the fuel management and Nothing to do with my Entire Car,lights,shut off etc..?
That relay has nothing to do with the rest of your electrical system. Lights work regardless of the ECU. That's probably a totally different issue probably related to your battery terminals.
